BMW DKG gearbox conversion
Old Jul 27, 2020 | 02:40 PM
260DET's Avatar
260DET
Originally Posted by doug
i hate you
Hello manual transmission
Old Jul 28, 2020 | 02:57 AM
tcode's Avatar
tcode
Gearbox control unit:
Old Jul 29, 2020 | 04:30 AM
tcode's Avatar
tcode
A bit of progress. Preparing mechantronic board for soldering, there are tiny aluminium wires connecting pads with motherboard. Those need to be removed as close as possible at pad surface. Also, silicone gel should be removed and degreasing of pads to be able to solder wires later.
After cleaning, a good amount of time needed to do it properly:
Work on gearbox to GCU cable, 26 wires in concentric twist I've done for the first time in my life. 1.8 meter (5.9 feet) long. It turned out quite well I believe.
Old Jul 29, 2020 | 11:25 AM
GreyZ's Avatar
GreyZ
What changes need to be made to the BMW Motherboard. While the CAD was obviously a challenge, I beleive that this step of re-soldering would likely be the most tedious step for others trying to follow as you have done .
Old Jul 29, 2020 | 02:25 PM
Frostydc4's Avatar
Frostydc4
Are you planning on driving the car in manual mode all of the time?
Old Jul 29, 2020 | 02:28 PM
tcode's Avatar
tcode
Basically you need to wire all 10 solenoids and sensors to a GCU, OEM motherboard isn't used at all, just pads on sides. There are several ways to do this.
At the end it should look something like this:
Old Jul 29, 2020 | 02:30 PM
tcode's Avatar
tcode
No, there is an automatic mode too.
Old Jul 29, 2020 | 04:13 PM
Frostydc4's Avatar
Frostydc4
Do you have to do any tuning for the auto modes?
Old Jul 30, 2020 | 12:54 AM
tcode's Avatar
tcode
Yes, but it is pretty straight forward, just two simple tables..
Old Jul 30, 2020 | 07:18 AM
Conway_160's Avatar
Conway_160
So is there no throttle input? Just a basic it will shift at XXX rpm regardless of throttle?
Old Jul 30, 2020 | 07:56 AM
tcode's Avatar
tcode
No, you need PPS value too. PPS = Pedal Possition Sensor.
Old Jul 30, 2020 | 11:01 AM
Conway_160's Avatar
Conway_160
Do you just tap of the OEM pedal?
Old Jul 30, 2020 | 11:31 AM
tcode's Avatar
tcode
You could, GCU can be configured to accept analog inputs. More elegant soulution is to get data through CAN BUS.
Old Jul 30, 2020 | 06:19 PM
Conway_160's Avatar
Conway_160
Ahhhh
Old Aug 10, 2020 | 01:54 AM
tcode's Avatar
tcode
Adapter for new gerbox connector is done too.
Three sets ready..
This project is postponed for couple of weeks.
This is the reason
Old Aug 10, 2020 | 04:56 AM
Conway_160's Avatar
Conway_160
Looks good man! Can't wait to see this thing in action.
Old Nov 17, 2020 | 05:21 AM
tcode's Avatar
tcode
Finally I'm getting back to this project.
Fit like a glove.
Old Nov 17, 2020 | 06:39 AM
  #38
tcode's Avatar
tcode
Added coating at flywheel and connection part:
Wiring 90% done:
And went from Haltech pro plugin to the Elite 2500:
Oh, it should be fun winter..
Old Nov 17, 2020 | 07:20 AM
  #39
bealljk's Avatar
bealljk
^badass Tom!
Impressive to say the least!
Old Nov 17, 2020 | 07:32 AM
  #40
tcode's Avatar
tcode
Originally Posted by bealljk
^badass Tom!
Thanks James! As always, I'm doing the best I can.
