What upgrades should i make/get before getting/while getting twin turbo
Old Aug 14, 2020 | 07:56 PM
Splununk's Avatar
Splununk
Question What upgrades should i make/get before getting/while getting twin turbo
So im here getting a 350z 2003-2005 and i am planing great and unheard things for it. But lets get to the main topic for this thread i am planing on putting a twin turbo in for it and i genuinely know what i need but not sure what specific options/ brands are good with everything that should go with it any ideas?
Old Aug 16, 2020 | 04:35 AM
itsLeon's Avatar
itsLeon
Lets start with how much power you want
Old Aug 16, 2020 | 05:16 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
And your mileage, compression, leakdown numbers ANNNND budget. Not to mention brake setup, suspension, tires.
Old Aug 16, 2020 | 09:26 AM
bealljk's Avatar
bealljk
what Mic said... how much money do you realistically want to throw at this?
Are you dead set on twin turbos? Would you consider a mid-mount or a front mount turbo? Possibly a rear-mount turbo? Twins are expensive, difficult (meaning expensive) to install, a little bit more money to maintain, and if (and when) something goes wrong they are extremely time consuming and expensive to perform maintenance on.
Old Aug 24, 2020 | 06:37 AM
Splununk's Avatar
Splununk
500-600 any around here would be good this is also going to be a project car so i do intend it to be more maintenance than my daily and i am fully prepared for that
Old Aug 24, 2020 | 08:03 AM
bealljk's Avatar
bealljk
500 to 600hp (on a DE motor) will run you about $10k to $15k when it's all said and done - do you want to spend this much?
$3k upgraded engine internals/gaskets/fluids/misc engine stuff
$1k for machine shop expenses
$1k flywheel / clutch package
$3k to $10k for a twin turbo setup
$1k for software/tuning platform
$1k dyno tuning
$1k exhaust setup
Old Aug 25, 2020 | 10:38 PM
itsLeon's Avatar
itsLeon
$1k dyno tuning
$1k exhaust setup
Don't know if you can get away with the $3k for the engine and misc stuff. Maybe you need a little bit more, for stuff like fuel pump, injectors, fuel rail, wideband sensors. Other then that seems about right give or take.
Old Aug 25, 2020 | 11:07 PM
bealljk's Avatar
bealljk
I totally forgot fuel!! Add $1k to $2k depending on what you want!
Old Aug 26, 2020 | 05:30 AM
GreyZ's Avatar
GreyZ
For that power it is likely cheaper to start with an HR, don't touch the motor and go with the BP kit. On pump E you should have no issues hitting those power numbers. I would still expect to be around the 10k area. There are some things that bealljk listed that can be had for cheaper, like the tuning and exhaust, and this would eliminate the 4k in motor build. You should add some cooling mods though, and likely a diff build.
Old Aug 26, 2020 | 07:29 AM
bealljk's Avatar
bealljk
All very good points … I would say the flip side of seeking an HR is that they will cost more on the front end and if/when things go wrong they will be harder / more expensive to fix. But definitely a viable-route to at least explore.
Brandon@VTR
Jun 8, 2019 12:36 PM
BojanC350z
Mar 22, 2007 07:44 PM
Pastapuck
Aug 21, 2005 10:00 AM
lemonjihwan
Aug 22, 2003 08:21 AM
jfive
Nov 6, 2002 05:18 PM
