swap a DE into a 2006 body?
Old Oct 16, 2020 | 02:58 PM
vdf97's Avatar
vdf97
Default swap a DE into a 2006 body?
Hey guys. Crazy i know. My HR engine blew in my 2006 roadster, i’m swapping it with a spare DE just so i can get it running. I know it’s a back step, but i just need to know: what parts do i need to make this swap happen? I know there’s differences between the two, so what do I need to put the DE engine in the 2006? I have the ECM for both, just don’t know where to start.
Old Oct 16, 2020 | 05:54 PM
DarkZ03's Avatar
DarkZ03
Your engine is a DE revup, not HR. If I had to guess, you will need ECU, harness, BCM, maybe more.
Old Oct 17, 2020 | 05:26 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
So let me see if I can clear something up here that is mighty confusing....
Is this the same car that was crashed (and internally bent) in your other thread ( https://my350z.com/forum/engine-and-...ter-crash.html ) that you were trying to salvage the engine to "put in another car"? Yet, this thread seems to say that you're trying to replace the supposed HR that you have in the ZR (despite bent frame) with a DE engine. Which is it??
Please get your stories straight for the benefit of those who can help you.
Old Oct 17, 2020 | 07:58 AM
vdf97's Avatar
vdf97
Dude chill. I have an 05 roadster with the DE, which is said vehicle from the other thread. The engine is salvageable. I found an 06 roadster for very cheap with a blown HR engine. I’m going to swap the HR out of the 06, and put my 05 DE in the 06.
Old Oct 17, 2020 | 07:59 AM
vdf97's Avatar
vdf97
Read it a little more clearly, and with a lot less judgement, and you’ll see that I specifically said this in the second to last sentence.
Old Oct 17, 2020 | 10:28 AM
travlee's Avatar
travlee
Master
06 is revup motor, get your shiiite straight
Old Oct 17, 2020 | 10:31 AM
travlee's Avatar
travlee
Master
Also.....with all this money you are spending , you could have paid for full coverage
Old Oct 17, 2020 | 11:15 AM
vdf97's Avatar
vdf97
if u can’t answer my question then bug out dude.
Old Oct 17, 2020 | 02:52 PM
travlee's Avatar
travlee
Master
Awwww, is someone upset? Do you need colors and a safe space?
Old Oct 17, 2020 | 04:10 PM
MicVelo's Avatar
And you'll note I said: "Please get your stories straight for the benefit of those who can help you."
Part of my job here is to untangle the messes so that people can get their problems solved. It was not clear what you were trying to do.
So if you want to take whatever is said as "judgemental" then you are in the wrong place. That clear enough?
Old Oct 17, 2020 | 07:33 PM
vdf97's Avatar
vdf97
well if you read what i posted clearly, there wouldn’t have been any confusion.
A facebook group was more help than y’all. Whatever. I figured out what I need to do.
Old Oct 18, 2020 | 05:58 AM
Heel Til I Die's Avatar
Heel Til I Die
Ah yes, the elusive HR engine in a '06. Some say they've seen it...
Doubtful. None of this makes any sense.
So, what did you learn?
Old Oct 18, 2020 | 10:02 AM
travlee's Avatar
travlee
Master
how to be in the camber gang retard crew
SMCM24
Oct 26, 2020 10:19 AM
BabyZ33
May 3, 2019 02:20 PM
racer59
Aug 20, 2010 05:18 PM
fergraz
Puerto Rico
16
Dec 17, 2007 11:59 AM
fastmike
Europe
Apr 10, 2004 10:57 AM
