350z Reverse light hookup
Old Nov 24, 2020 | 05:46 PM
Oki_Fairlady_ZR's Avatar
Oki_Fairlady_ZR
Default 350z Reverse light hookup
I've been searching for hours, and I can't find it here or the FSM.
i recently completed the 5AT to 6MT swap. I kept the ECM and harness.
I have the reverse plug for the MT but I don't know what wire to tap into.
The car already has a backup camera that worked when I put the automatic into reverse, and I would like for it to work again.
There's a decent sized Green plug off the right side of the old transmission that has nothing to plug into on the new manual, from the FSM I believe it's called an A/T assembly Harness. But I can't for the life of me find a pin out guide.
I do not want to wire the reverse plug directly to the reverse lights because I'm sure that will not trigger the back up camera,
So which wire is the correct one to tap into?
JDM 2005 Fairlady convertible touring trim if it matters.
Old Mar 19, 2021 | 09:31 AM
Conway_160's Avatar
Conway_160
Originally Posted by dolamio
You should start your own school on how do installations, I mean that. People where I'm from, break 192.168.100.1 192.168.1.1 all the time.
Is there a reason why everything you are typing is underlined?
Old Mar 19, 2021 | 12:55 PM
iideadeyeii's Avatar
iideadeyeii
The taillights directly will turn the camera on
Old Mar 19, 2021 | 12:59 PM
Heel Til I Die's Avatar
Heel Til I Die
It's because it's a spam bot.
Old Mar 20, 2021 | 05:23 AM
Oki_Fairlady_ZR
In case anyone stumbles across this, I've unfortunately become somewhat of the "go to" guy for transmission swaps on 350z in my area...
Since completing mine, I've done 3 more...
Anyway, the answers you may be looking for.
The neutral position switch is pretty easy to find on this forum, it's pin number 43 I believe, a yellow wire with a red strip. Add a line to the 12v positive on the battery, splice it into the wire or cut it and wire it directly into the IPDM. Tomato TomAto.
For the reverse switch...
Run a 12v positive to one side of the reverse switch, the other side will go to your Reverse relay just infront of the battery on the left, when you pull out the relay you will see 4 pins, like this... (sorry I don't have a picture)
___I___I___
___I___I___
__---------___ THIS IS THE ONE YOU WANT.
__---------___
I took the wire, stripped it, shoved it into the female connector side, and shoved the relay back into place. Most beautiful solution? no. Did it work? Yes.
Back up camera and reverse lights both activated when the car was put into reverse. I called it a win and moved on.
If you have any questions, I can't help. I won't be using this account anymore as I have sold the 350z convertible (I bought it to flip it for a profit) made a killing off it since I swapped it to a manual and I will NEVER buy a Z again. They are ***** cars. Sorry not sorry.
02.R1
Jan 29, 2012 09:54 AM
absurdparadox
Mar 20, 2011 09:25 PM
ag0240
Jun 19, 2009 01:08 PM
Merck
Feb 5, 2009 05:45 AM
Mr_Kebo
Jul 13, 2007 02:49 PM
