Please help indentify this part of the coolant system
Old Dec 13, 2021 | 11:40 AM
08HR350Z's Avatar
08HR350Z
Default Please help indentify this part of the coolant system
Hi there
I
The part with radiator cap that leads into the motor is leaking from top and the bolts connected to the motor. Thanks in advance
pressure tested my radiator system and it is leaking from the top a little and from the bolts on this part here. There's fluid all over my motor and it keeps happening. Please help me identify this part I need that leads from upper radiator hose and cap into the motor. Thanks in advance
Old Dec 14, 2021 | 06:38 AM
jhc's Avatar
jhc
General & Tech Moderator
There may be a fancier name but it's a "water outlet." If the outlet is cracked, replace it. Otherwise buy/make a new gasket and seal both sides with RTV. Tighten like a spark plug (about 15 ft lbs.) Gl!
Old Dec 14, 2021 | 07:01 AM
08HR350Z's Avatar
08HR350Z
Its mostly leaking from the bolts and little bit out of the upper radiator hose. Where to find the seals? O ring isn't it?Also I can't find that part anywhere any ideas? Thanks for the help
Old Dec 14, 2021 | 09:12 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
https://www.nissanpartsdeal.com/part...tra2=&filter=()
Garyh315223
Jun 11, 2024 08:45 PM
mforno
Sep 7, 2017 07:28 AM
lcf8088
Apr 13, 2014 07:01 AM
Stinvil93
Dec 30, 2013 02:06 PM
soshiv
Jan 29, 2008 06:43 AM
