Water pump mount bolts loosened themselves!
Old Feb 23, 2022 | 10:11 AM
Jeff Stein's Avatar
Jeff Stein
Exclamation Water pump mount bolts loosened themselves!
Hello everyone, my 2003 350z started to leak coolant out of the water pump weep hole. So I ordered a new pump, thermostat, and chain tensioner to replace them all. The car would make the traditional timing chain rattle on cold start noise so I figured maybe the tensioner was causing the rattle. But to my surprise when I went to remove the water pump mounting bolts two of them were backing out (bottom left almost a whole half-inch)!! Glad I got in there to do this job but I am wondering if the loose water pump mounting bolts could make it seep past the o-rings and the pump seals are still okay.
The car only has 85k miles on it but it is a built and vortech supercharged motor. Does anyone know how those bolts could get loose like that other than not being torqued enough, maybe the timing chain rattle helped? Assuming it's the oem pump in there.
Old Feb 23, 2022 | 10:48 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Why not loctite those bolts in place with some medium blue? After that you can check for more leakage in the area.
Old Feb 23, 2022 | 11:23 AM
jhc's Avatar
jhc
General & Tech Moderator
^^^^ Bingo. This!
10 years on here, never heard of a water pump failing under 100K. Gl!
Old Feb 23, 2022 | 11:46 AM
Jeff Stein's Avatar
Jeff Stein
Sounds like a plan, thinking I should change the chain tensioner out at least to see if it fixes my start-up rattle. I will update with the results.
Old Feb 23, 2022 | 01:28 PM
Ponyryd's Avatar
Ponyryd
Loctite or Teflon thread sealer, either will work.
But yes, tensioner while you’re in there.
Yoaris Garc ia
Oct 30, 2024 01:34 PM
MikesCar
Aug 16, 2021 12:09 PM
bankswood
Sep 11, 2016 03:30 AM
Detroitnook
Jun 20, 2016 01:43 AM
Newfoundbiker
Jun 4, 2009 07:33 AM
