Throttle body head bolt stripped
Old Mar 24, 2022 | 05:19 PM
MyZ4U2C's Avatar
MyZ4U2C
Default Throttle body head bolt stripped
Was trying to remove the throttle body and the top 2 bolts no prob. Got to the bottom right hand side and i guess the 5mm allen socket wasnt at the right angle and now the ***** is stripped. Any ideas on how i can get it out?
Old Mar 25, 2022 | 04:20 AM
travlee's Avatar
travlee
Master
i would try an extractor bit
Old Mar 25, 2022 | 04:47 PM
Ponyryd's Avatar
Ponyryd
Depends how stripped it is. You could try hammering in a torx but that’s a little too big and hope for the best, or you could try pounding a socket over the head thats a little too small. Make sure all the other bolts are out before trying this, that will help it come out much easier.
Old Mar 27, 2022 | 08:14 PM
bealljk's Avatar
bealljk
Can I assume you’ve taken the plunum off the car?
If not, take it off and use vice-grips or the aforementioned extractor bolt.
ecop_z33
May 19, 2020 04:33 PM
Jan 22, 2018 05:51 PM
JAM3Z
Dec 17, 2009 06:00 AM
itsjoshufocker
Apr 1, 2005 01:35 PM
