Weird Clanking = bad driveshaft U-joint?
Old May 26, 2022 | 10:09 AM
Void's Avatar
Void
Default Weird Clanking = bad driveshaft U-joint?
Hey all, 2003 350z Touring AT owner here.
ive been experiencing some clanking noise coming from underneath my car, especially when I drive at low speeds. When it was put on a lift at some random local shop just to see if something is loose, there was a lot of play in the drivetrain and I was told it could be the bearing inside the driveshaft but another mechanic I trust but who was out of town told me it was probably the universal joint in the driveshaft.
ill admit I’m kind of a noob when it comes to this stuff so would anyone tell me based on the sounds in the video if it’s likely the u-joint or something else and if it’s an expensive fix. Doing some googling I think I’m looking at like 400$ total with labor if it’s the u-joint. Sounds about right?
thank you all in advance! Kinda freaking out lol I hope it’s nothing major...
File Type: mov
Last edited by Void; May 26, 2022 at 10:16 AM. Reason: Just to say thanks in the end and mention year model
Old May 26, 2022 | 10:21 AM
joelle king's Avatar
joelle king
did u check your engine belt ? the quality and level of oil ? how often do you change it ?
Old May 26, 2022 | 10:38 AM
Void's Avatar
Void
the sound isn’t coming from the engine 100%. Checked it inside the cabin, checked it running when I popped the hood. The oil has been changed recently I only use Mobil1 synthetic. The belts have no cracks I don’t think it’s relevant at all. I’m a noob but that not much of a noob to confuse engine knock from some weird clanking😂
ti837
Sep 22, 2015 07:46 AM
Moodyd
May 14, 2015 06:37 AM
350Z400rwhp
Dec 28, 2013 05:36 AM
pmarascal
Jun 21, 2013 07:08 AM
blah159
Dec 16, 2012 11:22 AM
