Input Shaft Bearing Noise, Is it normal?
I have a 2003 Touring. I had the transmission replaced just under a year ago. I noticed a whirring noise when the car was in neutral but when I pressed the clutch pedal down the noise went away. I took this back to the dealer and they assured me it was normal yet I don't recall this noise before. I am about a week away from 1 year and I am wondering if I should have this looked at before my 1 year warranty is up? I have only put 4,000 miles with this new transmission and it has made this noise the whole time. Here is a video of it
Thanks in advance.
The Z transmission has heavy duty, large diameter gears (when shifting you’re quite aware of moving some heavy metal around). In neutral with the engine running, the transmission input shaft is turning. This shaft is geared to the counter shaft, spinning it and all the gears on it. Each gear on the counter shaft is in mesh with and spins the corresponding main gears. Basically everything in the transmission except the output shaft and the sliding shift collars is spinning. This can make quite a calliope of whirring and whining sounds. When you push on the clutch pedal the input shaft is disconnected from the engine and everything inside the transmission stops turning and falls silent.
Your you tube video isn’t working, but every new Z owner has had the experience of pulling into a quiet garage with hard smooth cement floor and walls and wondered “what the hell is that”. This along with a bit of chatter from the throw-out bearing is normal for this Trans. Try to reload the you-tube video so that the real experts here can judge whether the sound is within the normal level.
I notice from the temperature gauge the engine and presumably the transmission are cold. Because of this, the engine is idling at about twice the normal speed which makes the trans noise more prominent. Does it not quite down a bit when warmed up? To my uneducated ear this sounds about the same as my Z and others I have listened to.
