My 350z misfires
Old Aug 11, 2022 | 12:46 PM
Norwegian_z's Avatar
Norwegian_z
Default My 350z misfires
My 350z says its missfire ( blinking engine light)
To fix this i have changed
-z1 coils on all 6 cylinders
-ngk sparkplugs on all 6 cylinders
- bosh knock sensor
-z1 bank sensors ( bank1 and 2)
-presure tested all cylinders.
it is still getting missfire when the engine gets resistance and i am out of ideas on what it can be.
Has anyone any suggestions to what it can be?
thanks in advance
Old Aug 11, 2022 | 05:38 PM
Timboj's Avatar
Timboj
I'm no expert on electrical, but maybe start by checking all of your ground-wire locations. Otherwise it may be an issue with the harness that you need to trace. You could always check the wiring for continuity with a multimeter (ECU and coil connector).
Old Aug 12, 2022 | 07:12 PM
DarkZ03's Avatar
DarkZ03
Make sure the coils are plugged in properly, easy to get the driver side bank mixed up.
Old Aug 15, 2022 | 11:57 PM
kakaboy's Avatar
kakaboy
- bosh knock sensor
thanks in advance
Have you checked codes?
Old Aug 16, 2022 | 05:57 AM
Norwegian_z
The only code i get is that one or more cylinders are misfireing
the code is: P0300
Old Aug 16, 2022 | 02:19 PM
kakaboy's Avatar
kakaboy
the code is: P0300
Maybe check injectors?
Old Aug 17, 2022 | 04:09 AM
Norwegian_z
I cleaned the injectors but i have bought new ones and also new map sensor and o2 sensor for both upstream and downstream
Old Aug 17, 2022 | 06:49 PM
DarkZ03's Avatar
DarkZ03
I'm gonna say it again, make sure the coils on the left side are plugged into the right connector, it is possible to mix up and it will misfire.
Old Aug 18, 2022 | 01:51 AM
Norwegian_z
im sorry for not answering you but i checked the coils yesterday and it must be right because i cant put them on another without make it stretch in a way it dont look natural
Old Aug 19, 2022 | 04:56 AM
kakaboy's Avatar
kakaboy
I agree with Dark. I also had left bank misfire issue and it was the connectors. The last connector does not go to the last coil as it would seem. I made this mistake too. The last connector goes to coil 4
Old Aug 19, 2022 | 08:47 AM
Norwegian_z
the way my coil on left bank is set up is( seen from the front of the car) first connectror to first cylinder, second connector to third cylinder and last connector to the cylinder in the middel
Old Aug 19, 2022 | 09:41 AM
DarkZ03's Avatar
DarkZ03
That should be correct then I believe, mine isn't exactly routed like stock but that sounds right.
Old Aug 20, 2022 | 12:36 AM
kakaboy's Avatar
kakaboy
thats the right orientation
Old Aug 20, 2022 | 05:44 AM
i8acobra's Avatar
i8acobra
Plugged cats. Common Nissan issue.
Old Aug 20, 2022 | 06:38 AM
Norwegian_z
but that would not affect to a missfire? Just loss in power?🧐
Old Aug 20, 2022 | 08:36 AM
joelle king's Avatar
joelle king
My 350z says its missfire ( blinking engine light)To fix this i have changed
- bosh knock sensor
thanks in advance
I had a similar issue in the past and turned out that my injectors are not performing well
Old Aug 20, 2022 | 09:03 AM
Norwegian_z
yes i hope im getting the new injectors next week. If that not work i also have 02 sensors and new grain pipes. AND IF THATS NOT WORKING IM CRASHING THE **** IN A WALL
Old Aug 21, 2022 | 05:49 AM
i8acobra's Avatar
i8acobra
Yes, it can cause a misfire.
Cameron Kipp
Aug 10, 2021 10:28 PM
djmojo21
Jan 10, 2016 11:49 AM
los@350
South East
Jan 3, 2015 06:18 AM
