Starting problems
Old Sep 4, 2022 | 08:14 AM
zeddd's Avatar
zeddd
Unhappy Starting problems
Hi Guys,
i have strange problem with my Z. Recently i bought 350z with starting problem. Obd scanner shows fault P0335 which is Crankshaft sensor fault, so i bought a new one. (Old one was disconnected). I visually check the wire, but doesnt look Interrupted. With disconected sensor the car starts on second try then engine runs and drives well. When i fitted and connected new sensor car just cranking and doesnt start. Also there is no fault in obd scanner(it is not a cheap scanner from ebay, but professional one) . If i disconected sensor car start on second try. (I have 3x 350Z's so i try new sensor on my other cars and they started well with that sensor). I also change the spark plugs but with no change. Otherwise the car works perfectly, I have driven over 600 miles with it, but it always starts on the second attempt only with the crank-sensor disconnected. What to do next?
Old Sep 6, 2022 | 07:59 AM
iideadeyeii's Avatar
iideadeyeii
Was the flywheel taken out and put back in?
Old Sep 13, 2022 | 10:59 AM
zeddd's Avatar
zeddd
Nope
Old Sep 13, 2022 | 12:05 PM
iideadeyeii
Did you put an oem sensor? Non-oem sensors have been known to cause issues
Old Sep 13, 2022 | 12:12 PM
zeddd's Avatar
zeddd
No, but i have 3x 350Z, so i tried this sensor my other cars and it works well. Also i tried to put original sensor from one of my other Z's and no difference. Still have same starting problems.
Old Feb 29, 2024 | 07:40 PM
EgoDeath's Avatar
EgoDeath
Did you end up figuring it out? I’m having the same problem so I’m just running on my same old crank sensor. I’ve tried 2 new sensors already lol
Old Mar 2, 2024 | 01:01 PM
zeddd's Avatar
zeddd
If you're 100% sure that sensor is ok, the problem is in the wiring loom that leads to the sensor. You have to separate the wiring insulation and check the cables for any breaks/demage
Kanedaz350
Jan 27, 2022 08:54 PM
Pat D
Sep 1, 2018 05:51 PM
pr_350z
May 28, 2014 08:39 AM
arc2010
Jun 3, 2013 03:16 AM
Abdulrhman Khal
Jul 11, 2011 12:26 AM
