DE baffled oil pan?
Old Apr 27, 2023 | 08:46 AM
atoz33's Avatar
atoz33
Default DE baffled oil pan?
One of the guys in here looking to track their de. Not interested in moving to an hr right now and I'm looking for baffling and better oil capacity. All I'm finding right now is a greddy and stillen pan. Not interested in the stillen as it has no baffling but does anybody know where I can get a pan with actual proper baffling that isnt just the tiny walls in the greddy for a de? Or if somebody here has one for sale I'd be willing to buy one
Old Apr 27, 2023 | 06:56 PM
DarkZ03's Avatar
DarkZ03
There isn't anything with really good baffling, the only ones that have something at all would be Greddy and Central 20.
Old Apr 28, 2023 | 09:11 AM
iideadeyeii's Avatar
iideadeyeii
Have you considered just an oil pan spacer for increased capacity? You also space the pickup tube
Old Apr 28, 2023 | 10:27 AM
atoz33's Avatar
atoz33
I have but I really want something baffled like the old arc, ams, and og greddy pans. They used to make good de pans with real baffles but it's impossible to find some now
Old Apr 28, 2023 | 07:40 PM
DarkZ03's Avatar
DarkZ03
How come I've never seen them?
No ARC, no AMS.
Old Apr 28, 2023 | 07:44 PM
atoz33's Avatar
atoz33
No ARC, no AMS.
I've only found them searching old threads and surfing the internet I don't know the last time they were even sold
Old May 18, 2023 | 10:46 AM
Aeneas137's Avatar
Aeneas137
The DE doesn't have the same oil return problems as like say a Cayman engine which is notorious for that. there is a split oil pan system in the DE engine that means you really don't need baffling for high g oil pickup. an upper oil pan, and a lower. The upper handles oil return out of the heads, etc. this is probably why there isn't much of a market for a baffled oil pin.
Old May 19, 2023 | 05:58 AM
terrasmak's Avatar
Greddy is not baffled , just a hair more capacity. I have one on my car.
best to find the Cosworth parts imo , and good luck in your search
Old May 19, 2023 | 07:17 PM
DarkZ03's Avatar
DarkZ03
Does it not have those small walls around the pickup?
Old May 20, 2023 | 08:36 PM
Kwame's Avatar
Kwame
You need to find a used APS Oil Pan and the Cosworth Oil Control Baffle Kit
Old May 22, 2023 | 12:50 AM
isy_nismo's Avatar
isy_nismo
What about th rev up engine?
Old May 22, 2023 | 08:52 AM
terrasmak's Avatar
they have a version for that engine too
Old May 22, 2023 | 04:03 PM
Kwame's Avatar
Kwame
Old Aug 12, 2023 | 09:24 AM
martin231_day's Avatar
martin231_day
Old Aug 12, 2023 | 12:24 PM
Aeneas137's Avatar
Aeneas137
A 1-in spacer makes a huge difference with an extra quart of capacity. If you have an engine oil cooler also, there's room for probably another whole quart in the system. with the cooler, you're looking at 7Q. I noticed an improvement back in May after installing the 1-in spacer, and doing 2 hours of open track with hardly a break, no problems at all. whereas, previously with the stock pan at Sonoma, I could literally hear the pickup sucking air and losing oil pressure on high speed turns. and yeah, that's a scary sound, I left the track immediately.
Old Aug 12, 2023 | 02:17 PM
bealljk's Avatar
bealljk
Depending on the size of the cooler … I’m going to say the typical 12 to 20 rows hold 1/2quart at most, that includes lines. Its less than you think
It’s not the smartest but you can run two spacers and it does sit right below the bottom of the subframe plane.
Old Dec 12, 2023 | 10:50 AM
Desert Z's Avatar
Desert Z
I have the Concept Z baffled oil pan for my 06 rev up. I have not installed it it's sitting on a shelf. I'll install it soon.
Old Dec 24, 2023 | 11:04 AM
VQplatform's Avatar
VQplatform
Are you willing to sell the pan?
driftin_350
Sep 18, 2021 04:57 AM
crazyjeys
Jan 24, 2017 08:49 AM
35reilly
Jul 11, 2016 01:31 PM
Yaustinz33
Aug 20, 2015 05:48 PM
Mamounas123
Dec 17, 2008 08:26 PM
