Grease the splines or no?
Old May 6, 2023 | 03:54 PM
Justin35's Avatar
Justin35
5 Year Member
Default Grease the splines or no?
I spent a chunk of my day wrestling this bastard out from my Z. I understand grease needs to go along the collar, but should I also grease the splines? (fixing axle click)
thank you,
edit: what the hell; one more question. Do I really need to replace the cv axle nuts/bolts/washers? You know, the 7 or so that attach this axle to the diff.
Old May 7, 2023 | 06:06 AM
travlee's Avatar
travlee
Master
yes grease
Old May 7, 2023 | 06:21 AM
i8acobra's Avatar
i8acobra
Either moly grease or anti-seize. NOT red bearing grease. As a dealer tech I used to do a couple every week.
Old May 7, 2023 | 05:34 PM
Justin35's Avatar
Justin35
5 Year Member
Thanks.
Red on the collar, anti-seize or moly (which I have) on the splines.
Old May 7, 2023 | 06:16 PM
i8acobra's Avatar
i8acobra
Moly everywhere. No red anywhere. I was a Nissan Tech for 4 years and didn't even own a tub of red. The TSB specifically says to apply moly grease to the face.
Old May 8, 2023 | 06:55 AM
Heel Til I Die's Avatar
Heel Til I Die
Yeah, you're supposed to do that. I forget what I was doing when I had to remove the diff (maybe Whiteline bushings?) and I reused everything. I haven't had any problems, but YMMV.
Old May 9, 2023 | 08:46 AM
Justin35's Avatar
Justin35
5 Year Member
I think I will also reuse, but will use blue loc tite on them as well.
Old Jul 13, 2023 | 01:15 PM
MoneyMatt's Avatar
MoneyMatt
Considering its like ~$80 just for the hardware, +1 on some blue loctite.
jjs350zed
197
Mar 19, 2018 02:41 PM
Z&G's Parts Dis
20
Sep 11, 2016 09:23 AM
jdm0830
Jan 1, 2016 09:41 AM
3hree5ive0ero
58
Dec 9, 2012 12:28 PM
zeer0
Jun 5, 2011 12:33 AM
