Replace front main seal without removing front end?
Old Mar 28, 2024 | 12:09 PM
Bak3rme's Avatar
Bak3rme
Originally Posted by mcubed45
Haha thanks good eye!
I was gonna post another thread asking for tips on installing the spacer. I had to really work it to get the pulley bracket off. I can't even get the edge of the spacer started. Even with the ps bracket bolts loosened... I can't get a good angle to pry the bracket at all for extra clearance either. Any tips?
I think I saw a video where someone grinded the spacer down a bit to get it to fit..
Also is it ok to leave the other idler pulley bracket bolts off? They bottom out without the bracket.
Check this vid out @ the 9:20 mark! Might give visual help on how he got the spacer in. If you got the Z1 kit, then the supplied spacer should be a nissan part which is the correct dimension it needs to be (I would not suggest grinding as it can misalign the belt and run it off).
Also, OK to leave the idler pulley bracket/pulley off. saves a bit of weight (if you are into that weight savings territory) as I removed mine altogether (only put the bolts back in that fit without exposed threads)
CFAUVEL
Aug 22, 2021 05:03 PM
Bak3rme
Jun 1, 2020 12:28 PM
Enriquez2000
Feb 27, 2019 08:53 AM
Enriquez2000
Feb 11, 2019 12:53 PM
Nano
Jun 8, 2005 05:21 AM
