Front main seal replacement?
Old Feb 10, 2019 | 12:53 PM
Enriquez2000's Avatar
Enriquez2000
Default Front main seal replacement?
Found a huge dripping leak when cars running that at first looked like oil pan. Its a constant flow. I sprayed under the car and looks like its actually flowing from behind the crank... assuming that the front main is toasted.
from the service manual breakout it looks like i remove belts, remove pulley, remove old seal put new one in and reassemble...
just want to verify from anyone that may have done this.
Old Feb 10, 2019 | 03:49 PM
dkmura's Avatar
dkmura
General & DIY Moderator
If there's a major leak in the front of your VQ, it's likely not that easy. How many miles are on your Z? .
Old Feb 10, 2019 | 03:54 PM
Enriquez2000
it has 120k... it looks like its strwam8ng down the front from the crank pulley. Not sure what else would be there
Old Feb 10, 2019 | 04:08 PM
dkmura's Avatar
dkmura
The cause of this leak could be anything from a cracked oil pan, fitting or seal. Do you have the tools and skills to pull the front end and possibly pull the VQ? Do you have the time (and garage) to spare if complications arise?
Old Feb 10, 2019 | 04:15 PM
Enriquez2000
definitely not the oil pan... i cleaned everything and started the car and watched the river run from behind the crank pulley.
and yes i have the ability and storage, i just dont see whqt else it could be when i cleaned it all and visually watched it coming from behind the pulley
Old Feb 11, 2019 | 05:16 AM
RobPhoboS's Avatar
RobPhoboS
Kind of ignore this - I misread something.
Maybe you know this stuff, maybe not...but
Pretty easy, you might need to get yourself an engine support brace because you'll need to remove the engine sub-frame and hold the engine in place, and move the steering rack out of the way a bit (I didn't disconnect it, just moved it). You need to do that because the upper oil pan won't come out otherwise.
If you do that with the steering rack, make sure you put some paint marks on the upper and lower part of the yoke to get your steering lined up when you put it back together.
My engine support brace had a couple of chains with it, and I bought a couple of 1 ton support straps to wrap around the engine mounts, it did the job fine just ensure you do it neat as possible as the weight will remove the slack quickly if you aren't careful.
I found WD40 softens the old RTV, and a few plastic scrapers make reasonably light work of removing it all.
There are a couple of pry spots on the upper oil pan (near bolts 1 & 2), just over half way along and pointing towards the front of the car IIRC. There are a couple of dowel pins near there which is why it's the prying point.
Check the FSM on page EM-27 onwards, have fun
Old Feb 11, 2019 | 05:20 AM
Enriquez2000
so does the front Main seal require pulling all the timing cover stuff off? It looks like it presses in from the front
Old Feb 11, 2019 | 05:27 AM
RobPhoboS's Avatar
RobPhoboS
Apologies I mis-read something initially.
If it's the crank seal, you'll need to pull the front timing case off as well unfortunately, if it's the upper oil pan seal then you won't need to worry about the timing case.
These images may help you a little and I'd still replace the upper oil pan seals anway:
Old Feb 11, 2019 | 05:30 AM
Enriquez2000
correct me if I'm not seeing something correctly but it looks like that seal can pop right out the front and you press back in. That's also how the diagram breakout makes it look as well. If I'm wrong could you explain why I would need to pull the timing cover?
looking at this it could be that upper oil pan seal which would be why it looks like it's running a river behind the crank pulley. I was thinking front Main because it's a steady flow at idle rather than just a few drips
Old Feb 11, 2019 | 05:37 AM
RobPhoboS's Avatar
RobPhoboS
If you're sure it's just that crank seal, you can definitely pry it out, so yep give it a go ! (carefully as you can of course)
Pressing it back in should be ok with a big socket I imagine. I used a flat race bearing press to get it in (quite tough) but I can't see any reason why you can't try your way first
Old Feb 11, 2019 | 05:39 AM
Enriquez2000
as soon as I get the crank pulley off it should be obvious if it's the main seal or the upper pan gasket I would imagine. This is my first go with the VQ give me a Honda motor and I'd be able to tell you right away what it was LOL
Old Feb 11, 2019 | 05:42 AM
RobPhoboS's Avatar
RobPhoboS
Ah it's not too different, just a bit bigger and probably less space to work with
Depending on your intentions with the car, it's well worth doing a few preventative bits with the mileage/age but if it's just a car to run around in, no worries.
Old Feb 11, 2019 | 05:44 AM
Enriquez2000
it's a procharged car and it's just a fun little thing for now. At some point I know it needs to be a built motor if I'm going to keep it and do anything else with it
Old Feb 11, 2019 | 05:59 AM
RobPhoboS's Avatar
RobPhoboS
Nice.
It might be worth posting something up when you tackle it, always useful for others.
Old Feb 11, 2019 | 06:03 AM
Enriquez2000
Nice.
will do! Once the pulleyss off I'll start taking pictures and hopefully help someone else down the road
Old Feb 11, 2019 | 06:23 AM
dkmura's Avatar
dkmura
Getting this bit of info makes me think you're wasting your time by just trying to put together a small fix. With 120K and FI, it's time to build the shortblock at a minimum. Face it, this VQ was never designed for FI and has worn rapidly. All that labor goes to waste if you don't do the repair the right way.
Old Feb 11, 2019 | 12:50 PM
bealljk's Avatar
bealljk
Come DK - don't get dramatic!
yes, the VQ wasn't 'built' per say for FI but 8 or 9 psi of boost never hurt anyone...especially at elevation!
Old Feb 11, 2019 | 12:53 PM
Enriquez2000
and im pegging 7 max
redman333
Jul 6, 2008 03:20 PM
phunk
Mar 16, 2008 08:17 PM
ZCor
Jul 19, 2007 04:49 PM
TeesTru350Z
Aug 5, 2005 03:03 AM
