2005 ECU, BCM, and ignition in 2003
Old Dec 12, 2024 | 06:53 PM
k.z33's Avatar
k.z33
Default 2005 ECU, BCM, and ignition in 2003
Hi guys,
I recently bought a 2003 350z. The previous owner swapped it with a 2004.5 engine and used the newer engine harness with the wideband o2 sensors but kept the 2003 ECU. I'm getting a SES light because of that for the upstream sensors. A tuner I talked to told me that he could "tune" the ECU to act like a 2004.5 ECU. Is that a thing that works? Also, if I swap in the ECU, BCM, and ignition from a 2005 model 350z, would it be plug and play without needing to code in anything? or would it be easier to swap in a newer ECU and recode the NATS/BCM?
Old Dec 12, 2024 | 07:18 PM
k.z33's Avatar
k.z33
what would basically be the simplest solution to get the 2004.5 ECU into the car?
Old Dec 13, 2024 | 08:04 AM
seymore4's Avatar
seymore4
Professional
You can't reprogram an 03 ECU to be a 04.5. Its just not going to work.
Easiest option is to get the correct ECU and flash it with Uprev to delete NATS. Very simple to do.
Old Dec 13, 2024 | 09:09 AM
k.z33's Avatar
k.z33
Thanks I will try that. A shop in my area mentioned that they can reset the ECU so it will work without disabling the NATS. Is that a valid option to try?
Old Dec 13, 2024 | 09:22 AM
seymore4's Avatar
seymore4
Professional
Dealership can program the ECU as well
Old Dec 13, 2024 | 09:39 AM
k.z33's Avatar
k.z33
Thanks! Ill check with them as well. But just checking, I can directly swap the ECU without needing to change the BCM or the IPDM or anything correct?
Old Dec 13, 2024 | 11:18 AM
seymore4's Avatar
seymore4
Professional
Yes. If you want to go the Uprev route shoot me an email
Old Dec 14, 2024 | 08:56 AM
k.z33's Avatar
k.z33
Alright! Will do.
nonutz
Jul 24, 2022 09:43 AM
mustaffaa257
Dec 14, 2017 05:23 AM
thatv35guy
Jan 26, 2012 09:51 AM
diesel27
Tuning
Nov 3, 2005 08:41 PM
