Help
Old Dec 26, 2024 | 04:33 PM
amrossama46's Avatar
amrossama46
Default Help
Got 350z de engine
the car on cold start cranks but starts after long attempts
also running rich till warmup
changed the water temp sensor
also new fuel pump
checked also the injectors and they are working fine
any help ?
Old Dec 27, 2024 | 10:27 AM
bealljk's Avatar
bealljk
Any Check Engine Lights on?
Usually this is a combination of the following:
Wearing / worn out crank shaft and cam shaft position sensors (just replace all three of these with either OEM nissan or Hitachi brand only, and only purchase from a trusted source)
Clean and reset the Throttle Body
Clean the MAF sensor
Check your spark plugs to ensure they are not fouled
Make sure there are no vacuum leaks and make sure the intake is in good shape
pacificUp777
Nov 22, 2023 11:08 AM
Clickys350z
Mar 29, 2017 06:51 PM
sef4eg
Jan 27, 2014 12:12 AM
3FITTTY
Dec 31, 2008 06:20 AM
350zOnJuice
Apr 4, 2005 03:28 PM
