Contradictory info on rpm levels on European DE, revup and HR engines
Old Apr 22, 2025 | 10:39 AM
euZsearch's Avatar
euZsearch
Default Contradictory info on rpm levels on European DE, revup and HR engines
While researching 350Z engine types, I ran into this Z for sale in europe. A 2007 roadster, non-HR. I would assume that it's a revup, with the 7K redline. However, as you can see on the pictures, the redline is 6600 (non revup DE). Did the roadster Z come with different engine types/model years in Europe? Or just a case of a gauge cluster swap? Ad also says 280HP, but the registration check shows it was first registered in 2007... Thanks!
Old Apr 22, 2025 | 12:38 PM
Heel Til I Die's Avatar
Heel Til I Die
In the states, the rev-up and HR (06-09) came with an updated center console, and different tail lights and headlights (in addition to the obvious different engine). Other body differences included the hood "bump" on HR-equipped models while the rev-up retained the same hood style as the non rev-up DE with the two lines.
If this Z was in the states, it would be a non rev-up DE produced between 03-05.
Obviously, a picture of the engine would definitively tell you. Maybe the dealer can send you one?
Otherwise, it seems like this advertisement has false information.
Old Apr 22, 2025 | 12:48 PM
icer5160's Avatar
icer5160
The date of production seems way off, unless there were some regulatory issues with importing the HR equipped Zs into Europe. Or is date of production a translation mistake, maybe that's the initial registration date? But that is most definitely an 03-05 Roadster with the Non-Revup DE (at least from a US-Spec perspective).
Cheers!
-Icer
ChrisDe
Nov 9, 2018 04:09 PM
SexyRob
May 21, 2017 10:26 PM
StockAsFuhZ
Aug 17, 2012 08:40 AM
NiZMo1o1
Dec 13, 2009 01:11 PM
NiZMo1o1
NA Builds
21
Aug 6, 2008 09:09 AM
