Spark plugs
Old Mar 19, 2004 | 08:44 AM
maximumsportZ's Avatar
maximumsportZ
Default Spark plugs
Can someone tell me the nissan part # for stock NGK plat plugs? and also what should they be gapped at for the z ?
Thanks
Old Jun 17, 2004 | 08:35 AM
maximumsportZ
Bump. And whats the stock GAP for N/A.
Iridium or NGK plat?
Old Jun 17, 2004 | 08:41 AM
barrybell's Avatar
barrybell
Plugs from ESM
NGK Platinum
Standard: PLFR5A-11
Hot: PLFR4A-11
Cold: PLFR6A-11
Gap: 1.1mm (0.043 in.)
Old Jun 17, 2004 | 08:47 AM
redls1's Avatar
redls1
Stock gap .043
standard plug plfr5a-11
hot plfr4a-11
cold plfr6a-11
Old Jun 17, 2004 | 09:24 AM
maximumsportZ
Originally posted by redls1
Stock gap .043
hot plfr4a-11
cold plfr6a-11
Cool your in FL?? Hot or Cold? I'm NA would I need to use any of those or just stick with standard?
Thanks.
Old Jun 17, 2004 | 02:09 PM
peptidbond's Avatar
peptidbond
Stay with standard. No real need to run a cooler plug. Then again, if you get detonation in the future, then a colder plug would be good. However, some seriously believe in colder plugs even on a mostly stock car.
Old Jun 17, 2004 | 10:51 PM
shortcut3d's Avatar
shortcut3d
Get Iridium no matter what brand. Gap at .044. I prefer Denso Iridium.
In theory, a colder plug would allow our "intelligent" ECU to keep the timing more advanced. Our ECU takes many engine measurements and likes to retard timing and richen a:f.
Old Jun 23, 2004 | 07:51 AM
maximumsportZ
Thanks,
Ordered Denso Iridium IKH16.
Would I have to reset the ECU after i swap them??
Old Jun 23, 2004 | 02:57 PM
G3po's Avatar
G3po
Default plugs
Just a note , be "very" gentle when handling the Iridium plugs, the ceramic around the finer wire tip is very fragile and can easily crack if dropped etc. But they are definately about the best performing plugs you can buy both NA or FI.
burglapfd
Dec 6, 2020 01:04 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
35reilly
Sep 28, 2015 07:42 AM
