$160 for plugs? You smoking crack?!
Old Apr 1, 2004 | 11:10 AM
3rdpower's Avatar
3rdpower
Default $160 for plugs? You smoking crack?!
Went to the dealer last night and had them change the oil and I was just about to have my plugs changed when they came and told me it'd be $160. I about pee'ed my pants hahaa... Any DIY install plugs. Any estimates of time, difficulty (1-10 wrenches), and gap settings for Denso IK22 plugs. Thanks in advance for your information.
Old Apr 1, 2004 | 12:40 PM
mjedens's Avatar
mjedens
Default Plugs
DIY in about 45 minutes!! Curious on why you're using 2 degree colder plugs with your mods!
Old Apr 1, 2004 | 01:00 PM
3rdpower's Avatar
3rdpower
I'm going to Juice it in the near future or Turbo it in the not too distant future. Will it run bad w/ those plugs?
Old Apr 1, 2004 | 01:01 PM
SungNamZ's Avatar
SungNamZ
Denso is a great plug! DIY of 45 minutes once you figure out where to start and what to remove. The 2nd time goes even faster. Shouldn't have worry about gap or would want to.
Might want to consider ordering from: clubplug.net
Might want to look at the following sites:
densoiridium.com/powertechnology.php
denso.co.jp/en/
Old Apr 1, 2004 | 02:52 PM
ForceInduction's Avatar
ForceInduction
and I thought our price of $90 for those were steep.
Old Apr 1, 2004 | 05:46 PM
350xfire's Avatar
350xfire
That's almost as good as $250 for trans flush and fill.
Old Apr 1, 2004 | 06:35 PM
3rdpower's Avatar
3rdpower
The sad part is I have the plugs! They wanted to charge me $160 for instillation only. I cracked up the who way out the door.
Old Apr 2, 2004 | 12:58 PM
dwnshift's Avatar
dwnshift
Just from what we have seen with our cars in racing.........
DO NOT USE A COLDER SPARK PLUG WITH THIS ENGINE IF YOU ARE TRACKING YOUR 350Z!!!!
Big mistake for tracking. So far the best plug to use is the OEM heat range plug.
The spark plug sits in a water jacket.the colder the plug it moves the the heat more into the water jacket......your water temps will go through the roof....then when the water temps rise....VVTC starts shutting down.
Old Apr 2, 2004 | 09:52 PM
aznkukuboi's Avatar
aznkukuboi
haha wow... expenisve
Old Apr 8, 2004 | 01:03 PM
3rdpower's Avatar
3rdpower
not a good idea to install these plugs w/o fi application. Just got done taking them back out after a Engine Check Light
Old Apr 30, 2004 | 12:00 PM
E_Z_HOES's Avatar
E_Z_HOES
How are people having so many problems with IK22's? It's smooth sailing for me. I donno maybe because of the fact that my car was leaning out a little before I threw these plugs in but I actully made things smotther and haveing no problems with these plugs what so ever....... Evo R... you blew up 2 engines? I didne't know you caould blow up your engine with spark plugs.
Old Apr 30, 2004 | 03:25 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
you guys need to be using the H plug, not the std IK series.....IKs are far too short, and will cause the exact problem BJ described.
Let us know if you need them...we got plenty of the stock temp ones in stock, I can check on the others Monday. I guess I should add these to the site
burglapfd
Dec 6, 2020 01:04 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
35reilly
Sep 28, 2015 07:42 AM
