Stroker Kit
Old Apr 4, 2004 | 11:01 AM
frenzee's Avatar
frenzee
Originally posted by Z1 Performance
in its form shown at SEAM we were told it was not really meant for FI, though I imagine proper pistons could be spec'd for such purpose.
It came with both NA (11.0 and 11.5 compression ratio) and FI (8.5) pistons. The guy said that with the new sleeves and connecitng rods (which are the true weak links in the VQ engine) they had tested the engine up to 55psi of boost. It's on the website too. I don't know how accurate that statement is, but 55psi is one hella boost.
Old Apr 4, 2004 | 11:13 AM
frenzee's Avatar
frenzee
specs card
Old Apr 4, 2004 | 11:26 AM
frenzee's Avatar
frenzee
Originally posted by aalzuhair
This is the first time I have seen such a thing for the 350Z Looks like a good kit, do you have any idea how much it cost?
Thanks,
Az
I can't recall exactly. Either $4k or $8k. Maybe Tadashi can chime in. He and I were talking to the folks over at the PE booth about blowing a stroked engine!!!
Old Apr 4, 2004 | 11:38 AM
NismoKid's Avatar
NismoKid
Originally posted by basam350z
I'd love to do this instead of FI. The 11.5:1 should yield about 393 HP with 4.3 liters. You'd still have to upgrade fuel, injecters and the ECU.
There's always that Nismo* crate motor that has 450hp NA.
*Jeff and Jason spoke to Nismo USA reps a while back and they said they don't make it even though there was a Nimso serial # pictured on Overboost.com.
Old Apr 4, 2004 | 11:47 AM
bigern1970's Avatar
bigern1970
Default Re: Stroker Kit
Originally posted by frenzee
With the search function being down, I don't know if this has been discussed b4, but I saw this kit from AEBS Racing at the LA SEMA show yesterday.
kit looks nice i rotated pic stop hurting your neck now
Old Apr 4, 2004 | 11:55 AM
ThoughtZ's Avatar
ThoughtZ
dear god 55 boost, hell you can crack close to 400 with fi at 8-9 psi. i cant even imagine adding this thing to my car, nevermind i can and i will lol
Old Apr 4, 2004 | 12:46 PM
PhoenixINX's Avatar
PhoenixINX
The 55 psi of boost wasn't on a VQ engine, is was on a b-series Honda motor. Check out their t-sleeves... sick stuff! I couldnt' imagine a 2500 lbs Honda hatch boosting 50 psi... GEEEZUS!
I wouldn't mind seeing them build a VQ block to handle 1.5 - 2BAR safely.
Even then... bottomline it comes down to tuning.
That 55psi setup... don't get it right, and BOOM.
Old Apr 4, 2004 | 04:26 PM
phile's Avatar
phile
Followed by 300 years of nuclear fallout JK :P
Old Apr 4, 2004 | 04:41 PM
ether's Avatar
ether
did they mention availability?
Old Apr 4, 2004 | 05:32 PM
VQ35Kompressor's Avatar
VQ35Kompressor
Hmmm...wonder if 11.5 CR with that stroker kit is ok with the stupid *** 91 gas we have in Cali??? If not, with that setup and some Tomei 264 cams will be nice!!!
Old Apr 4, 2004 | 06:10 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
it's made but not offered for sale to the general public, and not anything that involved NISMO USA (whcih has nothing in common really to NISMO Japan)
Old Apr 4, 2004 | 06:24 PM
infidsg35's Avatar
infidsg35
How exactly does increasing liters make more power?
Old Apr 4, 2004 | 06:41 PM
FLY BY Z's Avatar
FLY BY Z
Allows the engine to flow more air. That is the name of the game, right? More capacity.
Old Apr 4, 2004 | 07:01 PM
infidsg35's Avatar
infidsg35
Ha Ha my girlfriends brother just gave me "motors 101" talk lol.. It will up the cubic inches of the motor which will allow more air to flow. With that you will have to tune the ECU for more fuel and probably change the injectors..
So basiclly more air, more fuel, stronger components = More HP!
He also said torque will be nicely increased as well
Old Apr 4, 2004 | 07:05 PM
Z1 Performance
Former Sponsor
As good as AEBS is - what does 'tested at 55 psi of boost mean"....granted thats ALOT of boost, but it really tells you nothing
I just wonder how this thing qwould rev, and what cams would be well suited to it - stock Z has absolutely nothing upstairs as it is
Old Apr 4, 2004 | 07:07 PM
Jsn350Z's Avatar
Jsn350Z
I too am intrested in how it would rev.
Old Apr 4, 2004 | 07:34 PM
mchapman's Avatar
mchapman
This could be a good alternative to boosting.
I hope more information is made available in the near future.
Old Apr 4, 2004 | 07:47 PM
  #38
FLY BY Z's Avatar
FLY BY Z
How it would rev depends on what you do with the valvetrain. We race V8's that we shift at 8K RPMs. Yes, the overall potential of RPM will be lower with a stroked motor, but it will not be less than what a built valvetrain is capable of. Especially on a street motor. With built heads, you can still rev the VQ to 7K or 8K if you want to no matter what displacement you have it at.
infindsg35, liters is the metric way to measure cubic inches. so, technically, i guess increasing liters does increase cubic inches, although one does not cause the other. it's the same.
Old Apr 4, 2004 | 08:40 PM
  #39
frenzee's Avatar
frenzee
This is strictly a guess, but maybe the 11.0 pistons were made for us Californians with our lame 91 octane pump gas.
As for revving smoothly and how well-balanced it's going to be, well that's the $64k question; it will probably suffer from top end power due to more mass traveling a larger diameter circle (i.e. the bigger crank, plus the rods), but the stock VQ hp peaks around 5,800 rpm anyhow, doesn't it? I think the low down torque is where the gains are going to be, and if I'm right the gains will be substantial over stock (i.e. >22% in added displacement) and more importantly it should be a linear increase throughout the low- and mid-rmp range. But this is just my opinion. We won't know for sure until someone actually takes the plunge, so to speak.
Old Apr 4, 2004 | 09:45 PM
  #40
mchapman's Avatar
mchapman
So when is someone going to get it, soon I hope
Is it on the market yet?
