base with aftermarket LSD? or enthusiast?
Old Apr 14, 2004 | 03:37 PM
toykilla's Avatar
toykilla
Default base with aftermarket LSD? or enthusiast?
HELP! .. What would be the advantages/disadvantages of going with either:
base model and aftermarket LSD
enthusiast model with stock LSD
Old Apr 14, 2004 | 04:46 PM
Moroccan_Mole's Avatar
Moroccan_Mole
i would probably go with the base with the upgraded lsd.
keep in mind you will have no form of traction control (not sure if this is an issue to you) and no hids.
the best thing might actually to go with the enthusiest with an upgraded lsd, heh.
it depends on what you plan on doing with the car
Old Apr 14, 2004 | 05:03 PM
Hey Ya's Avatar
Hey Ya
If you have an extra lsd, I'll buy your old one. It should fit my G right?
Old Apr 15, 2004 | 08:41 AM
kzshin's Avatar
kzshin
The fact is the stock LSD doesn't perform as well as Aftermarket LSD when you have bigger and stickier tires. You can read this whole technical issues on Sport Compact Car magazine. I got a base model Z, because I know even if I get the enthuiast modle, I will swap out the Stock LSD with the aftermarket one. So why pay more for something you will swap out eventually. However, if you will keep everything stock, then just get the Z with Stock LSD.
Old Apr 15, 2004 | 08:53 AM
USMC-Z's Avatar
USMC-Z
Z Veteran
Depends on what you will be using the car for mostly. If you are going to be tracking the car a lot, then go with the aftermarket lsd. If the car will be a daily driver, it will be a pain in the *** to have an aftermarket. Ive heard that they make grinding noises and jerk the car at low speeds. No need for an aftermarket lsd if you won't be using its full potential, such as a track with turns.
edit: The latter is true for the clutch type differentials
Old Apr 15, 2004 | 09:37 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
base w/ NISMO locker!!!!
http://www.performancenissanparts.co...products_id=59
Old Apr 15, 2004 | 09:43 AM
Chebosto's Avatar
Chebosto
the viscous lsd will not be up to it if you track the Z... even with the cooler.. i would suggest you get an aftermarket Z..
get the base.
buy HIDs. buy the LSD and bigger brakes. and then you'll be set.
oh yea. and those plastic undertray diffuser off the track model ...
Old Apr 17, 2004 | 08:58 AM
Traffic's Avatar
Traffic
toykilla,
tell us how you intend to use the car, then I can recommend one or the other for you.
Old Jul 17, 2004 | 05:24 PM
thawk408's Avatar
thawk408
Sorry for bringing up an old thread. But, how much can the stock LSD handle, such as in TT applications? I am very interested in this topic as I am facing the same problem.
SharX59
Sep 27, 2015 09:23 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
