installed b&m short throw shifter
Old Apr 17, 2004 | 06:06 PM
Melissa's Avatar
Melissa
Default installed b&m short throw shifter
man this is the absolute best 200 dollars i have spent!!!!!!!!
they say it reduces the throw by 30% but i swear it seems like more....its almost just flicking your wrist to shift gears....put together well and it is great......shifts are very precise and crisp!!!!
thanks alot b&m
Old Apr 17, 2004 | 06:16 PM
ypwpat's Avatar
ypwpat
is there any added vibration or noise from your gear?
Old Apr 17, 2004 | 06:19 PM
Melissa's Avatar
Melissa
no noise or vibration at all....it is extreamly sturdy....man you cant go wrong with this thing i swear......i was amazed at this thing...very rugged and well built
Old Apr 17, 2004 | 06:30 PM
fairladyZ in Japan's Avatar
fairladyZ in Japan
Default Re: installed b&m short throw shifter
thanks alot b&m
All right, Melissa !!!! That's the music & feedback I was hoping to hear.
1/ Just like ypwpat asked .. how's the vibration from idle through the RPM range ? Any noise ?
2/ Just checking .. the stock plate goes over the blue mounting plate that comes with the shifter -- correct ?
3/ When you filed 0.125" off the upper and upper left side of the shifter casing... how many inches from the upper left corner ?
Thanks... can't wait to get this installed !
Old Apr 17, 2004 | 06:33 PM
mode101's Avatar
mode101
did you happen to take some pics of the install ?
Old Apr 17, 2004 | 06:45 PM
Melissa's Avatar
Melissa
no pics sorry...i was in a rush...was installing kinetix plenum and zex wet n2o kit also.....so i had to move fast.......
now as for the other questions
i get absolutely no vibration at any point in the rpms or idle....
no noise at all
stock plate goes ove blue one yes...now got to be carefull here....best thing to do when tightening down is put in fifth gear and slide factory plate towards the shifter til it stops..then tighten down...if you dont do this the shifter will go past fifth and sith and youll have trouble fing fifth ...also it will go into reverse without pushing down if you dont......
now for the filing....the whole oening in the shifter cup is only about 1 1/2 x 2 inches....i just filed with a hand file all the way down the left side of it to insure i didnt have to pull it apart again and refile....i also did about 1/4 inch instead of an 1/8th for the same reason.....took all of 5 minutes to file........
let me know if you have any other questions
john
Old Apr 17, 2004 | 07:17 PM
mucky's Avatar
mucky
I get a wierd vibrating noise and can't seem to figure it out. Only around 4000k and I also get a wierd noise when shifting. don't notice any vibration though. I thought it was excess grease around the black piece, but I tremoved it all. Then iI noticed some kind of fluid around the ball that goes into the gold color ball. If anyone has any ideas please help me out.
Thanks,
Matt
Old Apr 17, 2004 | 07:27 PM
CarbonZ's Avatar
CarbonZ
show some of the pics of it installed please. i really wanna see how it looks!!! Pleeeeaaaasssseeeee
Thanx
Old Apr 17, 2004 | 07:37 PM
Melissa's Avatar
Melissa
it really looks stock.....its about 1/2 inch shorter....the throw is enough that if you have it in 2nd 4th or 6th and looking into the car it almost looks to be in neutural.......ill try to takes some pics...but i wont be able to post them til tuesday or wednesday
Old Apr 17, 2004 | 07:49 PM
fairladyZ in Japan
John (aka Melissa)...
Thank you so much ... your posts have been a BIG help.
Old Apr 17, 2004 | 07:58 PM
Melissa's Avatar
Melissa
any time you guys.....also if you have any other questions just pm me......
Old Apr 17, 2004 | 08:37 PM
350ed's Avatar
350ed
Professional
Cool, looking forward to installing.
Old Apr 17, 2004 | 08:57 PM
dholly1's Avatar
dholly1
Filing? What's up with the filing? Are you filing the oem top plate, new blue top plate, new pivot cup or what?
Old Apr 17, 2004 | 09:15 PM
fairladyZ in Japan
No ... not the stock plate .. not the new blue plate...
After removing the stock shifter -- you have to file down the opening ... which is the hole in the shifter casing...
Old Apr 18, 2004 | 07:32 AM
MIAPLAYA's Avatar
MIAPLAYA
I'd like to see how this holds up in the long run. A lot of people with the B15 B&M shifter raved and gave great reviews but then they started dropping like flies. It seems like one would break every other day. Please keep us posted.
Old Apr 18, 2004 | 08:22 AM
3rdpower's Avatar
3rdpower
I'm gettin' mines on Monday... will hopefully install Monday as well...
Old Apr 18, 2004 | 12:29 PM
denic79's Avatar
denic79
I installed mine took me about an hour. Went for a test drive. It is GREAT!!!!!!!!!!!
Second gear is right there. You do have to get used to it. I think it's different from the stock one. Best 200 I spent.
When you install the shift **** back easy with the threads on the new one because there very softand I stripped mine and had to rethread it. But no vibration or nothing.
I will get some pictures it looks sweat. New leather bag and the short titanium ****.
Old Apr 19, 2004 | 06:52 AM
Road Warrior's Avatar
Road Warrior
well sounds great....with the shorter throws is there any more of a chance of mis-shift?
i think the stock setup is great but if it can be improved and the gears are as easy to find i would go for some shorter throws...
Old Apr 19, 2004 | 07:25 AM
Th3Cleaner's Avatar
Th3Cleaner
Is this a Nismo part that you guys have installed?
edit:
duh ... B&M
would it void the waranty?
I am trying to mod car but go through Nismo and dealer as to keep waranty good... thx
Old Apr 19, 2004 | 10:26 AM
3rdpower's Avatar
3rdpower
Good luck getting any power. Just remember any mod done to your car doesn't just magically void the warranty. FI of course would and CAMs may IF they can link the problem directly to the part which you have modified.
As far as the B&M Shifter goes it is unproven and could (just like any other thing Short Throw Shifter) cause syncro problems... hope this isn't the case.
