Service Engine Light, WTF (need help)
Old May 1, 2004 | 06:42 PM
zand02max's Avatar
zand02max
Default Service Engine Light, WTF (need help)
I have 2600 miles, installed the JWT PopCharger at 2200 miles. On the way back from a road trip toad, my service engine light pops on.
How do I get this to go away? Will the dealer fix it? What about my popcharger? Will the dealer say its that Mod and charge me to turn the light off?
Should I disconnect the negative battery terminal? And if so, for how long?
Thanks for any help!
Old May 1, 2004 | 07:04 PM
SQUILL's Avatar
SQUILL
Default Re: Service Engine Light, WTF (need help)
Disconnecting the battery does nothing for the 350z here is Z a link to the correct wat to reset your factory ecu . Keep in mind though this service engine light may be unrelated to your popcharger and you might be ignoring a serious problem!
http://www.technosquareinc.com/350reset.htm
Old May 1, 2004 | 07:42 PM
zand02max's Avatar
zand02max
So my ? is, if it doesn't turn off, should I take the JWT pop charger off before i go to the dealer?
Old May 1, 2004 | 07:44 PM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
Take it to AutoZone or a similar place and see what the code says, they can clear it if you want.
Old May 1, 2004 | 08:09 PM
Z_Coaster's Avatar
Z_Coaster
Suggest putting the stock intake back on and going to the dealer for a possible ECM reflash.
https://my350z.com/forum/showthread....threadid=68892
https://my350z.com/forum/showthread....threadid=36863
Old May 1, 2004 | 08:25 PM
zand02max's Avatar
zand02max
Well I tried to reset it, no luck. I will take it to auto zone and see if they can reset it.
I DO NOT want to take the Pop charger off just for the dealer to reset the Check Engine Light.
My question is, do I have to take it off? I am almost certain the dealer will say its the po charger causeing the engine light to go on, and they will charge me to reset it.
Figures, the week after I pay it off, crap starts going wrong.
Old May 1, 2004 | 09:11 PM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
You can always buy the little gizmo they use to check it for about $100
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
Fixxxercask
Nov 9, 2015 11:10 AM
samansharif
Sep 25, 2015 12:31 PM
