shift light wire?
Old May 7, 2004 | 07:16 PM
spdu4ia's Avatar
spdu4ia
Default shift light wire?
I am looking to add a LED shift light and was wondering what color/location of the shift light wire that is in the stock tach was? can you just tap into that and have a brighter shift light that way?
Old May 7, 2004 | 09:50 PM
ares's Avatar
ares
Veteran
find its positive and use it. assuming its a full 12 volts, if theres a resistor in the line(which I dont know if there is), you have to measure what its actual current is and then adjust from there.
Old May 9, 2004 | 08:03 AM
Jun's Avatar
Jun
yes you can, some guy in here did it, installed to small LED bulbs. You have to remove your cluster though to access it.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
sherm
Apr 11, 2020 05:21 PM
samansharif
Sep 25, 2015 12:31 PM
