Vq4.0
Old May 14, 2004 | 05:16 PM
DuckyZgiirl's Avatar
DuckyZgiirl
Default Vq4.0
Is it possible and or has anyone fit the new VQ4.0 in a 350Z or G35? Would wieght be an issue for the front? I hear those engines can make 310hp.
Old May 14, 2004 | 06:53 PM
RoadRagerInTherapy's Avatar
RoadRagerInTherapy
There's a lot of easier ways to add 23bhp to a Z (310-287=23) than doing a motor-swap...
...that's why nobody would waste their time/money doing this.
Old May 14, 2004 | 07:15 PM
DuckyZgiirl
but that just the start add a turbo and you can get what 550-625hp almost?
Old May 14, 2004 | 08:15 PM
RoadRagerInTherapy
...and why would an extra 12.5% displacement make that much difference when you're talking turbocharging...???
Old May 14, 2004 | 09:20 PM
DuckyZgiirl
better reving too.
Old May 14, 2004 | 10:55 PM
RoadRagerInTherapy
better reving too.
Where do you get that idea???
Old May 14, 2004 | 11:10 PM
apsilon's Avatar
apsilon
If you want more capacity you're probably better off looking at a stroker kit rather than try and swap engines.
Old May 14, 2004 | 11:20 PM
phatshiet's Avatar
phatshiet
Why not just buy the crank of the 4.0 and stick it into the 3.5 and have custom pistons and rods made. Have the crank balance and polished. This would be a sick setup for going turbo. It would probably be a cheaper alternative to a stroker and give you some good revs. I think the displacement would bump up to about 3.7 or so.
Old May 14, 2004 | 11:24 PM
ChuckGZ's Avatar
ChuckGZ
why not just put in a triton?
Old May 14, 2004 | 11:44 PM
DuckyZgiirl
cant i just install the pistons off the 4.0 and header too?
Old May 15, 2004 | 12:46 AM
RoadRagerInTherapy
Uhhhhh... why are you stuck on putting parts from a Pathfinder engine into a Z?
Why not go aftermarket/forged/better-than-stock if you're going to go through the trouble at all?
Old May 15, 2004 | 12:52 PM
BENJ-AMG's Avatar
BENJ-AMG
The V8 is too heavy. The cars balance would be screwed up. You'd have loads of understeer.
Old May 15, 2004 | 01:33 PM
DuckyZgiirl
I can get parts cheap since I know a couple of people.
Old May 15, 2004 | 02:00 PM
DuckyZgiirl
V8 I dunno what your talking about mister.
Old May 16, 2004 | 03:33 AM
ATI 350z's Avatar
ATI 350z
If you insist on doing an engine swap take a Q-45 @345hp at least you would feel that, 23xtra hp you would be very disapointed not to mention you wouldn"t even feel it
Old May 16, 2004 | 11:55 AM
DuckyZgiirl
well I can get the VQ40 cheaper and it pretty much weights the same, as the VQ35, the VK45 will drasticly change handling characterisitcs.
