For those of you using RED LINE motor oil....
Old Jul 23, 2004 | 02:37 PM
ppw350Zunit's Avatar
ppw350Zunit
Default For those of you using RED LINE motor oil....
RED LINE has to lines of motor oil. the regular high performance engine oil and the race oil. the high performance comes in 5W30 but the race oil doesn't. i was thinking about using the race oil 10W30. i heard it's recommended that you use 5W30. my question is which one are you guys using. thanks.
Old Jul 23, 2004 | 03:23 PM
Steel Heals's Avatar
Steel Heals
Default Re: For those of you using RED LINE motor oil....
It depends upon your climate. 5W-30 is recommended overall, but here in So Cal, where you and I both live, the Owner's Manual says that 10W-30 or 10W-40 are OK to use.
I use Royal Purple 10W-40, and the car runs great!
Old Jul 23, 2004 | 04:00 PM
MardiGrasMax's Avatar
MardiGrasMax
AFAIK, You should use the street oil because its addative package is designed for street use. Race has less addatives and wont stand up to long drain intervals.
I ran 10w30 RL and 10w40 in summer in my VQ with 5k drain interval and a filter change and top off at 2500. I did oil testing and the wear levels were fine, even runing 380whp, and used ithe boost every day!
Old Jul 23, 2004 | 04:09 PM
EddieJr's Avatar
EddieJr
Do not use Redline Race series oils in your street car engine. Even Redline advises against it......just use the regular stuff. I'm using the 10W30. If I can get my hands on their new 5W-40, that will go in the next on the next oil change.
Old Jul 23, 2004 | 04:43 PM
287HP's Avatar
287HP
I am using 10w40 Redline. Modified engines are going to run a little hotter. I think 10w40 is a good weight for modified cars.
Old Jul 23, 2004 | 06:33 PM
ragtopz's Avatar
ragtopz
10w 30... regular red line.
