Stock resonator removed = loss of power?
You can search the web for good reasons for backpressure but it's bunk science.
First, on the loss of power in the stock Z system with resonator removed,
1) Was the loss quantified by dyno testing or just butt dyno?
2) The stock exhaust system is just that, a system, it was tuned by Nissan to work best when it's all there. We don't have the faintest clue how they developed it but I have a good idea they spent a lot more time than most, if not all, of the aftermarket shops to get it to work best in all situations. Taking the resonator out could have upset some balance they designed into it, perhaps by unmasking inefficiencies of the rear muffler. Who knows
The need for backpressure comes from people who have experimented with large pipes, seen low end power losses and incorrectly deduced it must be a lack of back pressure that caused it when it fact it is a loss of gas velocity.
High Velocity, Low Restriction
Chris
Chris
Originally posted by ChrisMCagle
Well, I was able to obtain a new midpipe and as soon as I installed it yesterday the car is back to normal. There is a dramatic difference in the way the car accellerates now. I can't believe how much of a decrease in power it creates by replacing that little cannister with a straight pipe!
For anyone even thinking about cutting out their stock resonator.... DON'T!!! Your torque will go into the crapper!
-Chris
-Chris
One of the first things I noticed when I took delivery of my 350Z in December, 2002 was that the exhaust was too quiet. In less than a week I had the resonator removed at a custom performance exhaust shop.
Although I get some raspy buzz if I give it too much throttle when the exhaust system is cold, overall I really like the improvement in exhaust note. I'm convinced that I got a horsepower improvement, not only from the butt dyno but also from the real dyno a couple of weeks later when I rang in about 4 HP higher than my buddy who didn't get the cut.
If I had to do it over again I would still have the resonator removed. I have never heard anyone else report negative performance results from this simple mod.
Here Here JBrady
The "Backpressure Myth" must me stopped!
Chris
Chris
I'll find that article. It is very well written and directly contradicts you guys who believe that I'm full of it. .
As Chris pointed out, this myth originated with people trying larger pipe, assuming a backpressure drop and concluding backpressure is needed. The article you reference, although I haven't seen it yet, sounds to me as an attempt (however cleaverly crafted) to explain WHY backpressure would make power when it demonstrably does not.
Let us consider the "fact" used that this backpressure "packs" the cylinder during overlap. Now, in a 2 stroke the situation is MUCH different but in a NA 4 stroke (or as Pat McGivern aka Motoman accurately points out... 8 phase engine) you do not want exhaust port backpressure.
As I pointed out any backpressure while the piston is moving up from BDC will apply its force (pressure x piston area) against crankshaft rotation. In fact, in a highly tuned engine you can actually see vacuum during this phase and that vacuum can assist in "pulling" the piston up... effectively adding "free" horsepower...
Any backpressure during overlap can easily cause reversion in the intake port/manifold. Think about it, what could this pressure be "packing"? There is very little area available when the piston is at TDC and the intake cycle has just barely begun. The critical time when "packing" actually does occur is after BDC on the intake cycle when the intake is still open and the inertia of the intake charge continues to fill even as the piston begins its upstroke. Way before this, during overlap, if there is backpressure during overlap the intake flow is surpressed and the total intake volume is less than it could have been.
As I said, it is during the critical periods of the piston returning from BDC and then again during valve overlap where backpressure is most damaging to the efficiency/power.
Now, the above is still simplified and I have not given some examples of why larger pipes or things like resonators and collector shapes effect velocity and backpressure but again, it is the case.
Originally posted by bhobson333
This is very interesting. I strongly believe that your original resonator cut was botched somehow, with some obstructions left in the pipe that were fixed by your midpipe installation.
-Chris
-Chris
-Chris
350Z/370Z Tech Moderator
*2* stock resonators? Where are they located?
I find it interesting that that much loss of low end (as mentioned in this thread) resulted from removal of the stock resonator. Yes, well aware of loss of accelerative feel upon exhaust modifications but as much as these folks described?? Hmmmm.... it's not like they removed the cats, the resonator, rear muff and replaced with 4" straight pipe.
i too would love to see what *2* resonators you be talkin about, Willis. 😩😩
At first I thought they were my secondary cats, but the guy at the muffler shop told me they were my resonators. they were in between my cats and where the muffler was. I drive a Nissan Fuga 350GT. So I too was confused to here that I had *2* resinators rather than 1.
While it shares some similarities, the Fuga (Y51) is a different vehicle than the 350Z (Z33). My wife drives an Infiniti M35 (which would be the US equivalent of the Fuga/Y51). Yes, it does have 2 resonators.
What "custom" resonator did you have installed? It could be more restrictive than OEM.
Got it.
