Nismo Or Jwt Cams For Hp Gains
Old Jan 31, 2005 | 11:01 AM
topfri's Avatar
topfri
anyone know if the nismo cams are hollow like oem?
Old Jan 31, 2005 | 11:36 AM
sentry65's Avatar
sentry65
the burninator
I can't wait to get some decent tires/suspension so I can floor it in 1st gear again.
With my combo of mods - along with the JWT cams, in 1st gear after 5000rpms, the tires lose grip and the tact jumps to redline.
I'm guessing the main culprits for losing grip on stock tires w/track rays are the tilton, 3.9 final drive, and jwt cams
I had most of my bolt on mods put on at the same time so I can't comment on the JWT's loss of low end torque because my car's low end torque is either the same or higher than stock
speedform's Avatar
speedform
What are the average install costs and install time you guys are being quoted?
Old Jan 31, 2005 | 11:46 AM
sentry65's Avatar
sentry65
the burninator
If you're going NA for sure, I'd get the tomei cams or wait for what crawford comes up with.
JWT and nismo cams are a good compromise to get a decent boost, not lose TONS of low end torque, and still be suitable for FI.
I think I've heard average install cost is 800-1200 probably depending on the installer's experience
I don't know though. I paid 2500 to have all my stuff installed in one sitting
Old Feb 2, 2005 | 04:39 PM
ReavTek's Avatar
ReavTek
For the tomei cams what other additional parts will I need? I have been hearing you need to do valves, springs, etc.
Old Feb 2, 2005 | 05:02 PM
Machupo's Avatar
Machupo
sentry, you knockin' on the door of 300rwhp, yet?
i'm on my way to a pretty similar setup, might go with the tomei's though... still looking at what would go best with a bit of strokin'
Old Feb 2, 2005 | 05:05 PM
sentry65's Avatar
sentry65
the burninator
we'll see, I think the most I can hope for with my setup on a dyno is around 280-290whp at the most
last dyno I was at 268 - kinda disappointing, but oh well. I'm going to try out another dyno just for curiosity sakes.
My A/F still needs to get tweaked. I'm getting an A/F gauge installed so I can log with a laptop and have TS more accurately tune my car - gonna be about a month I'd guess till I see what numbers I'm putting down.
Old Feb 2, 2005 | 10:29 PM
jchen1020's Avatar
jchen1020
JWT is WAY to go. Set Idle at 850RPM, car will not stall anymore. High lift spring will help if you raise top RPM above 7000. Techno Square is good, but, you can take it in for custom ECU reflash. I use APEXI SAFCII to correct air/ fuel mixture.
Old Feb 2, 2005 | 10:33 PM
jchen1020's Avatar
jchen1020
Again, GREAT DEAL, DO NOT MISS OUT. 500 miles only
nanotech
Oct 2, 2015 05:02 AM
