Do 03 Maxima VQ heads work on 350Z?
I have a line on a set of heads off a Maxima but I need clarification on the variable timing issue......I think that was what was brought up before....but with the VQ30 heads.
I confirmed they are the same with my Nissan parts guru aka Dave Burnette at South Point Nissan.
He said the list above is correct, except 10/03+ production 2004.5 350Z, 11/02+ Altima, and 8/04+ Murano go to a new head part number.
ANY 2002-2003 Maxima head will work, however I'd double check to make sure with the VIN# incase there is a parts list mistake(happens). The "new" heads could just be a minor non-functional change, so they could still work.
I don't know about this particular application but as Ice suggested it could be for a minor non-functional difference.
A Nissan example was a buddy of mine had an engine failure on his 1990 Infiniti Q45 (rods through block due to cheap plastic cam chain tensioner... those were a crime on that engine) His car had the rare 4 wheel steering option. The Infiniti dealer told him he needed an engine from another car with 4WS... good luck... Finally, after failing to find an engine at a junkyard... I told him to ask the dealer what was the difference. Turned out there were 4 threaded holes needed. These holes were in a boss cast into all Q45 engines of those years but were only drilled and tapped for 4WS cars. I had him ask if they could drill and tap any engine... they said no problem... he quickly sourced an engine and the problem was solved.
Originally posted by IceY2K1Max
2003-2004 350Z
2002 VQ35 Altima
2002-2003 Maxima
2003-2004 Murano
All use 11090-8J100(left/front) and 11040-8J100(right/rear).
2003-2004 350Z
2002 VQ35 Altima
2002-2003 Maxima
2003-2004 Murano
11040-8J100
11090-8J100
YEAAHHH
Originally posted by pimp1911
g355gear. You going FI or NA.
2003-2004 350Z
2002 VQ35 Altima
2002-2003 Maxima
2003-2004 Murano
2003-2004 350Z
2002 VQ35 Altima
2002-2003 Maxima
2003-2004 Murano
The '04 Maxima uses different part numbers on most of it's internals. Part of the reason for this is because the VQ35 in the '04+ Maxima is manufactured in the Dechard engine plant in Tennesee. ANYONE seeking brand new OE parts for ANY VQ35 should first inquire about A34 engine parts because they cost a fraction of what the imported parts cost. For example a A34 VQ35 shortblock can be had as little as $1800 but a A33 shortblock will cost more than twice that. A33 valve covers are well over $100 each but A34 valve covers are less than $40 each.
Untill now it seems that the 350Z/G35 crowd hasn't been interested in reseraching the similarities between all the VQ35 engines however the Maxima crowd has been researching it extensively for quite some time.
