Nissan VS. TS ECU idle bump?????
Old Sep 24, 2004 | 08:32 AM
redline350ZZ's Avatar
redline350ZZ
Default Nissan VS. TS ECU idle bump?????
I had a Tilton flywheel installed a while ago and had Nissan bump the IDLE to 750-800 range......... a month later I decided to go with a TS ecu reflash to richen my fuel...due to CATS and raise the REV limit for the flywheel.... well I told them about the flywheel and they said that they could permanently raise the idle to 800..... they said that nissan used the consult tool to raise the IDLE and that a reflash would over-ride and reset what NISSAN did....
well it didnt and now my idle is @ 1000... what do i do????? I dont want to go to nissan and tell them about the REFLASH possibly killing whatever warrenty I have left???? Is there a way to mechanically lower the IDLE?????
better yet what happened????
Old Sep 24, 2004 | 09:22 AM
phunk's Avatar
phunk
CJ Motorsports
did you let the car warm up?
Old Sep 24, 2004 | 02:25 PM
redline350ZZ
yes im talking about idle permanently after the car has warmed up.....
Old Sep 24, 2004 | 02:35 PM
Zmego1985's Avatar
Zmego1985
I had them raise my idle to 900 for my cams. Why is it bad or something for the car to be at 1000?
Thanks Glen
Old Sep 24, 2004 | 03:14 PM
redline350ZZ
waste of gas......
Old Sep 24, 2004 | 04:03 PM
fdao's Avatar
fdao
I know it's a PITA, but why don't you just send it back to Technosquare to let them correct their mistake?
Old Sep 24, 2004 | 04:09 PM
redline350ZZ
The thing is...... who's RPM change should get fixed?????
TS did it permanently........ did NISSAN??????
I just want to get the right one changed back....
Old Sep 24, 2004 | 04:42 PM
fdao's Avatar
fdao
I would think Technosquare should be able to change it. How can it be permanently set at 1000 rpm? That doesn't sound logical. If it is permanently set, then how can the Consult II change it? Thus, what's the point of taking it back to the dealership?
Old Sep 24, 2004 | 05:40 PM
redline350ZZ
I mean that if you reset the ECU it wont go away.... TS said that once they reset my ECU that the NISSAN changes will go away... if I knew they were mistaken then I would have not asked them to change the IDLE......
I just want to know the diffrence in how NISSAN and TS changed the IDLE....
has to be two diffrent ways otherwise how do i have this confict????
Old Sep 24, 2004 | 09:49 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
They probably just made an error. They use the same technique that the consult does. Nothing is permanent. TS can always reflash to lower the idle.
Old Sep 25, 2004 | 12:08 AM
fdao's Avatar
fdao
My thoughts exactly, thanks.
Old Sep 28, 2004 | 11:03 AM
NOZ4U's Avatar
NOZ4U
Send it back to TS. I have the JWT flywheel and had them set mine @ 800 and it was perfect. I'm sure they'll correct it at no charge. I believe the Consult II will modify the parameters but it's not actually hardcoded into the ECU. Whereas TS flashes the EPROM (hardcodes) the new settings. Based on what I was told, if the dealer does any type of reflash, TS will flash your originally purchased program for free.
liqalu04
Jan 2, 2022 12:58 PM
sales@czp
Sep 23, 2019 03:30 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
