LSD Oil in Non-LSD
Old Oct 31, 2004 | 01:36 PM
mrZeee's Avatar
mrZeee
Question LSD Oil in Non-LSD
Got my gear box oil and rear diff changed out @10k...according to work slip, looks like dealer used LSD oil in my diff...I have the base Z with non LSD...will this cause any probs???
Old Oct 31, 2004 | 01:48 PM
manofsteele2003's Avatar
manofsteele2003
I don't think it'll make a difference. The LSD oil has an additive for the clutch packs in a diff with LSD.
Old Oct 31, 2004 | 02:01 PM
mrZeee's Avatar
mrZeee
thanks mos03...anyone else car to chime in??
Old Oct 31, 2004 | 07:50 PM
alininger2001's Avatar
alininger2001
Our limited slips do not have clutch plates, it's a Viscous limited slip. As far as I know VLSD's do not require the friction additives that are required with a clutch type limited slip. So as far as I know, our limited slips require normal oil, probably the same oil as an open diff. I will consult the service manual and get back to you.
Old Oct 31, 2004 | 08:03 PM
alininger2001
Yeah, there is only one oil listed in the service manual. Funny thing, our trannys take 75w95 but our diffs take 80w90. What's even funnier is that I've never heard of any of these 2 oil weights, they are very out of the ordinary, probably designed for our car specifically.
Old Oct 31, 2004 | 08:32 PM
mrZeee's Avatar
mrZeee
du-oh...thats right...it doesn't list diff oils for the different diffs..thanks alininger...and BTW...if your hoping swapping in fresh gear box oil will reduce tranny whine..it doesn't...don't have major whine...but its there...(still!)
Old Nov 4, 2004 | 05:50 PM
alininger2001
Take it to the dealer, I don't have a tranny whine, or have heard a z with one.
Old Nov 6, 2004 | 09:33 AM
mrZeee's Avatar
mrZeee
I don't believe I'm the only Z with "tranny whine"...waiting to see if it is more consistant though...as I said hoping fresh fluid would help...annoying beacuse its hard to pin down...
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
