Drivetrain loss 5AT?
Old Nov 12, 2004 | 04:15 PM
aron's Avatar
aron
Default Drivetrain loss 5AT?
Can someone tell me what the drivetrain loss is on a 5AT?
Thanks.
Old Nov 12, 2004 | 07:57 PM
JimH's Avatar
JimH
Default Re: Drivetrain loss 5AT?
My 03 dyno's at 225 HP and that is close to 22% loss. I swapped rearend gears from a 6MT and I now dyno @ 277 torque. This is about 50 ft. lbs. more torque than before and is higher than any stock 6MT. There is a slight fuel penalty, but not much. I can regularly out accelerate other 6MT's due to this. I've run a best of 13.901 @ 100 mph and she is box stock with 65,000 miles rung up! With the bigger wheels/tires, I am paying about 2/10's et penalty, I believe.
Regards, Jim
Thanks.
Old Nov 13, 2004 | 12:23 AM
ragtopz's Avatar
ragtopz
yeah, i believe it is roughly about 20% for the 5at and 15% for the 6mt.
btw, jimh i thought you left the forum. havent seen you in a long while. even though you may not remember me, it is good to see you again. i think the last post by you that i remember was something about a picture of a plaque you made.
Old Nov 13, 2004 | 05:16 AM
MySunset350Z's Avatar
MySunset350Z
what exactly is it you did to swap out gears with a 6mt jim?
Old Nov 13, 2004 | 06:51 AM
Q45tech's Avatar
Q45tech
The old rear 4AT of the Q45 resulted in a 22% loss [primarily tires and differential] in 1:1 gear test.
JATCO say the new [JR507E] 5AT is much more efficient thanks to lighter weight, small TC, and reduced internal pump losses.
Guess would be 21-20% with the viscous diff.
The whole efficiency thing varies greatly with ATF and diff temperature. Of cource tire brand inflation alignment [amount of rear camber and toe] and temperature can changes these 2-3%
Old Nov 13, 2004 | 07:18 AM
JimH's Avatar
JimH
Default Final drive swap
I found a wrecked (track) 6MT and arranged to swap my differential (whole assy) for its differential. This changed my final drive from 3.34 to 3.58. Because I had previously changed my rear tires/wheels to larger sizes, I was losing low end pull to the tune of roughly 2/10's in the 1/4 mile. I went from 13.9's to 14.2-3's with the upsizing in tires/wheels. The change in gearing gave this 2/10's back to me. I pay a small penalty in higher revs at highway speed, but it is not bad at all.
Regards, Jim
MAsSIVrOOM
Oct 20, 2023 10:50 AM
apex locator
Jul 23, 2021 02:27 AM
ablaine
Nov 29, 2016 10:13 AM
