Changing the Differential / Transmission Oil
Old Dec 3, 2007 | 05:13 PM
  #201
Asterix's Avatar
Asterix
Since the plates don't rub against one another, they're not clutches. It's more a torque converter than a clutch, according to that diagram. And, as you point out, they're in a sealed can, away from the gear oil, living in their own silicone heaven.
Asterix
Old Dec 3, 2007 | 06:46 PM
  #202
impacta's Avatar
impacta
Damn....Im wondering what I will expect with 62k on the car and ive NEVER changed the diff.. The tranny has had 2 flushes since i had the car though....5AT.
Old Dec 3, 2007 | 06:55 PM
  #203
Mike Wazowski's Avatar
Mike Wazowski
^^^ its gonna stink and be black...
Old Dec 7, 2007 | 11:56 AM
  #204
Diesel350's Avatar
Diesel350
So for the base Z will I see a difference by changing the differential oil to something like Motul 300 or Redline?
Old Dec 28, 2007 | 11:00 AM
  #205
kingrukus's Avatar
kingrukus
Is a suction gun absolutely required, or can I simply use a piece of flexible tubing pushed into the fill hole, with a funnel and have the fluid poured into it? This is the method I have used on previous vehicles...
Thx
Old Dec 28, 2007 | 11:03 AM
  #206
Mike Wazowski
you probably wont notice a thing if you have a base model since you have no LSD. I would just change and put Mobile 1 in it or Nissan Fluid.
Thx
a suction gun is ideal, but your way would probably work also. It would probably just waste more fluid over all.
Old Dec 28, 2007 | 11:07 AM
  #207
kingrukus's Avatar
kingrukus
And to absolutely confirm, 80w90 GL-5 fluid is to be used in the rear differential for the LSD equipped cars?
Old Dec 28, 2007 | 11:20 AM
  #208
Mike Wazowski
I used 75w90 GL-5
Old Dec 28, 2007 | 11:38 AM
  #209
VO...'s Avatar
VO...
Administrator
Thx
You might be able to get the diff done, but there's not alot of room by the tranny to get the container higher than the filler hole. The pump is only a couple bucks. No sense in doing it ghetto rig style...
Old Dec 28, 2007 | 11:48 AM
  #210
kingrukus's Avatar
kingrukus
Yup, I think i will just go with the pump. My previous cars have been FWD, so that I could route the tubing up through the engine bay and funnel it from there...thus gravity would act on the fluid and feed the tranny pretty well...I am obviously restricted height wise with the G, so I suppose I cannot do the same.
Old Dec 28, 2007 | 11:57 AM
  #211
VO...'s Avatar
VO...
Administrator
Good call. Did you see the write-up I did a few pages back?
Old Dec 28, 2007 | 12:15 PM
  #212
Mike Wazowski
how are you liking the Redline in the tranny? I have about 10K on the RP and I am thinking of switching to the redline (already bought it)
Old Dec 28, 2007 | 12:53 PM
  #213
kingrukus's Avatar
kingrukus
I just scrolled back and read it, excellent write up and pics. So it looks like I may need to re-consider going with the amsoil 75w90 and perhaps do the mix of redline 75w80 & 75w90 instead...
  #214
__jb's Avatar
__jb
Z + Rear Seat
What a nice thread...
I recently had a Carbonetics CF differential installed in my G35 Coupe, so I needed to change the fluid after the break in (200 miles). I purchased a siphon tool at advanced Auto Parts for about $14. It worked well, but leaked around the fittings a bit.
I also bought a Nissan differential cover... because it has fins to cool the diff and my 4.08 gears... and maybe because I think it looks neat...
Where did you guys get your suction pumps?
Old Dec 28, 2007 | 01:18 PM
  #215
VO...'s Avatar
VO...
Administrator
Here's how I responded to someone that PM'd me with the same question.
I changed the factory tranny fluid out with the synthetic Redline brand. Personally, I didn't see any difference in shifting smoothness. It feels identical to the OEM fluid. I think all the hype people make about how "smooth it feels" is just hype. Don't get me wrong, it's not bad, it just doesn't make the tranny shift any different than the OEM fluid would.
Now what goes on inside the tranny is a different story. It kinda like switching your motor oil out from conventional to synthetic. The driver never really feels anything different during acceleration or who quiet the engine runs, but we all know that the synthetic engine oil is benefitting the engine internally and offering better protection than it's conventional counterpart.
So I would say, given the characteristics of synthetic tranny blend vs. conventional blend, I would chose the synthetic blend.
Old Dec 28, 2007 | 02:41 PM
  #216
cavallino33's Avatar
cavallino33
This was a useful thread. I'll be doing it this weekend switching my nismo lsd to the correct motul fluid. I don't have 4 jack stands so I'm going to attempt to do it without lifting it, I'm able to fit under the car to the diff so hopefully all works out.
Old Dec 29, 2007 | 10:35 AM
  #217
Mike Wazowski
Just changed my tranny fluid this morning to the Redline mixture. soooo easy to do when you have a car lift. took me 18 minutes.
I was running the RP fluid previously, and I have to say I do notice a difference in shifting with the redline. It feels like a new tranny. The RP was good once it warmed up, but the redline was good from the start.
Old Dec 29, 2007 | 10:38 AM
  #218
SuperBlack350z's Avatar
SuperBlack350z
i feel the opposite. I think the redline sucks until i drive the at least 15 minutes before it feels good.
Old Dec 29, 2007 | 05:28 PM
  #219
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
Might have to check that out. I currently have the RP and when warm its aswsome, but when its cold its kinda notchy.
Old Dec 30, 2007 | 12:47 PM
  #220
cavallino33
Alright I did it today. I ended up having to jack up one side of the car for a moment to tighten the drain plug (torque wrench was too long) but I was able to do the rest with the car on the ground.
I used the Motul 90PA for my nismo lsd and it made a HUGE difference.
I think I'll be smelling gear oil for a week though.
