Changing the Differential / Transmission Oil
Old Apr 5, 2019 | 07:03 PM
  #561
VQdriver's Avatar
VQdriver
Originally Posted by noobie_1337
This is the correct redline product for the diff yes?
Red Line 57904 (75W90) Synthetic Gear Oil - 1 Quart
Also does anyone know the washer needed? (or if it's even necessary to replace it)
Thx
That’s the correct oil for the differential. You could save yourself a ton of money by using Castrol Hypoy C or equivalent 80W-90. No need to change the washer unless it’s currently leaking. I’ve changed mine a few times already. Can also use Valvoline 80W-90 or Supertech (Yes Walmart!) full synth 75W-90. I’ve used all those on various vehicles with great results and a fraction of the price of that expensive Redline. Nice to see the thread and forum alive! I still commute my G35 now at 128,000mi on original clutch.
Old Jan 15, 2021 | 11:33 AM
  #562
VO...'s Avatar
VO...
Administrator
Originally Posted by Wired 24/7
OK Guys, just ordered some transmission/diff drain plug washers.
If anyone wants the part number, it's
110264n200
you can find it at perf. nissan's OEM parts site
http://www.trademotion.com/partlocat...?siteid=214252
just plug it into the search function on their site
They're like $2 each... cheap insurance...
Also I bought the redline mt-90 stuff for the trans (GL-4), as well as redline 75w-90 gear oil for the diff (exceeds GL-5)
The hyperlink no longer works, but the part number is still valid. It pulls right up on Amazon. A bag of 10 crush washers for $5.99. They are oil drain plug washers, but compatible with the manual transmission and I'm sure the rear diffy as well. I placed a bag on order today...
Old Jan 15, 2021 | 04:39 PM
  #563
JRSport018's Avatar
JRSport018
Hey VO, where are you seeing $5.99? I'm seeing $10.99 + $10 shipping?
Amazon Amazon
allshownogo
Nov 7, 2018 06:20 AM
Bernardo Z33
Nov 7, 2018 05:45 AM
DeeZee
Jun 24, 2006 05:51 PM
ReavTek
Feb 28, 2005 08:20 AM
imcool
Dec 23, 2004 11:37 AM
