Turbo Timer Install Write Up
Old Sep 29, 2006 | 06:03 AM
  #41
THE TECH's Avatar
THE TECH
Originally Posted by XuperXero
I got the Apexi one, Just wondering where's the ECU and which pin is for O2 sensor. Apexi has A/F gauge but I need the pin from the ECu to read that.
How do I take off center console without breaking it for the ebrake wire? which one's ebrake wire?
Don't waste time hooking it up to the 02 sensor. The ECU is located under the passenger side dash. There are threads about taking apart the dash/console. Just search.
Old Sep 30, 2006 | 01:39 PM
  #42
k3silk's Avatar
k3silk
you also dont need the ebreak wire hook up i just tucked mine to the side. but i will like to hook up the a/f wire i heard that 06 have widebands although i have a innovate w/b in the car too.
Old Sep 30, 2006 | 03:12 PM
  #43
THE TECH's Avatar
THE TECH
Forget using the OEM sensors for a/f readings. Wideband or not, you should use a reliable aftermarket system if you want to read your air/fuel ratio.
Old Oct 1, 2006 | 04:04 PM
  #44
k3silk's Avatar
k3silk
I have one i was just asking.
Old Oct 2, 2006 | 08:07 PM
  #45
XuperXero's Avatar
XuperXero
Installed the turbo timer today. This write up is definitely thumbs up.
But I did some searching around and found that 2004.5 and 2005 models came with Wideband O2 sensor stock. The one that's before the cat. I have 2004.5. so, which ECU Pinout is the precat O2 sensor? Thanks.
Old Oct 13, 2006 | 01:32 PM
  #46
Mike Wazowski's Avatar
Mike Wazowski
I am going to be installing the Blitz tonight or tomorrow morning. Thanks again for the write up Mia.
Is anyone interested in step by step pictures as I go along?
Old Oct 13, 2006 | 03:17 PM
  #47
MIAPLAYA's Avatar
MIAPLAYA
No worries glad to help. I think some step by step pics would make this write up even better. Let me know if you get them and I will edit the original post to include your pics. Thanks again!!
Old Oct 13, 2006 | 04:45 PM
  #48
Mike Wazowski
I will PM you the links to the pictures tomorrow after I get done. I went to dinner instead tonight LOL
Old Oct 13, 2006 | 06:27 PM
  #49
MIAPLAYA's Avatar
MIAPLAYA
No worries. I'm in Maine on business and will be flying back tomorrow so I will upload and edit the thread tomorrow when I get home.
Old Oct 14, 2006 | 05:06 AM
  #50
Mike Wazowski
ok, I got a few pictures. I will upload them this afternoon. I didnt take a hell of a lot, because this install just goes by way to fast.
Old Oct 14, 2006 | 05:17 AM
  #51
MIAPLAYA's Avatar
MIAPLAYA
Sounds good, and I agree. I fully intended to take a bunch of pics but got done and realized I hadn't taken a single one.
Old Mar 27, 2007 | 07:12 AM
  #52
Zilvia's Avatar
Zilvia
so did any try this with HKS...
guess il just have give a shot
Old Mar 28, 2007 | 02:16 PM
  #53
xav_350z's Avatar
xav_350z
^guess not :P
Old Apr 30, 2007 | 01:57 PM
  #54
blazersman's Avatar
blazersman
i have an issue.... i installed my hks timer and my ignition fuse under the hood keeps blowing!
i tapped into my headunit wiring for power and accesory, hooked up the parking brake, and properly found the ignition wire under the steering column. has anyone else had this problem or have any suggestions?
Old May 1, 2007 | 11:09 AM
  #55
MIAPLAYA's Avatar
MIAPLAYA
What rating is that fuse? 10 amp or 15 amp? You shouldn't be blowing any fuses but if you are its a signal too much current is being run back into the ignition circuit from the turbo timer...
Old May 1, 2007 | 11:25 AM
  #56
blazersman's Avatar
blazersman
It's actually a 40amp fuse. And $15 a pop! Are you saying that it could be pulling too much power from the wiring from my stereo and pushing it to that fuse causing it to blow?
Old May 1, 2007 | 11:30 AM
  #57
MIAPLAYA's Avatar
MIAPLAYA
Yes its quite possible. Try re-tapping your power source from the wire on the ignition harness. On the same harness as the black with red wire under the steering column there is a white wire with a blue stripe. If you test it with the car off you should read a solid 12 volts. Try tapping your 12 volt source there. I have done that on the last three cars I installed turbo timers on (friends Zs and Gs) and it works just fine..
Old May 1, 2007 | 11:43 AM
  #58
blazersman's Avatar
blazersman
Cool... yeh I'll try that when I get some time. Thanks!
Old May 12, 2010 | 05:17 AM
  #59
JasonZ-YA's Avatar
JasonZ-YA
Default Greddy full auto turbo timer
This How to is great......made the install easy. Wanted to add pictures and will update the first post as the pics are dead. waiting for MIAPLAYA to see if he may still have them.
The greddy full auto Turbo timer hooks up exactly the same.....
It has a harness that has a white plug at the end........if you dont buy the "optional vehicle specific plug and play" harness then you need to cut the white plug off and strip the 3 wires.....
The three wires are thick wires that are BLUE, RED and GREEN.
To remove the lower plastic panel on the steering column you can follow POST 13 through 16 here:
https://my350z.com/forum/body-interi...t-install.html
The wires you need to splice into at the steering column are circled here - right above the tilt lever:
Here are two pics of the Greddy FULL AUTO TURBO TIMER and its configuration:
Wire connections from cut white harness plug removed:
GREDDY TURBO TIMER HARNESS
- 350Z STEERING COLUMN WIRES
RED WIRE - 12V (+) WHITE/blue stripe
GREEN WIRE - Ignition (+) BLACK/red stripe
BLUE WIRE - Accessory (+) WHITE/black stripe
BLACK WIRE with loop at end - Find a good ground under the dash.
PURPLE SPEED SIGNAL WIRE:
If you care to hook up the purple speed signal wire then you can connect it to the Z speed wire (white with green stripe) located at the back of the uni-meter (middle plug) - LOCATION SHOWN HERE:
https://my350z.com/forum/audio-and-v...t-ii-pics.html
Post 12 of this thread shows it in better detail.
BROWN PARKING WIRE:
I didn't hook this up, I simply grounded it with the black ground wire.
Obviously to connect it if you wish you would need to remove the center console and access the parking brake wires and test for 12v and 0volt wire as shown in the greddy manual pic.
GREDDY MANUAL:
To download the entire greddy turbo timer manual you can do so at greddy.com/tech support/ ~ scroll down to "turbo timer"
-J
Attached Thumbnails Turbo Timer Install Write Up-greddytt1.jpg   Turbo Timer Install Write Up-greddytt2.jpg   Turbo Timer Install Write Up-greddytt3.jpg
Old May 12, 2010 | 05:30 AM
  #60
JasonZ-YA's Avatar
JasonZ-YA
Also, the greddy turbo timer doesnt come with any kind of mount base or anything other that some sorry double sided tape.............we didnt use it but ended up getting a thicker double sided tape and it held, but im very doubtful it will hold under the dash plastic like that for long...........
I guess keep in mind mounting configuration when looking to do this install..
-J
