Idler Pulley Removal Mod with Pics
Old May 1, 2008 | 10:42 PM
  #81
kennyl5123's Avatar
kennyl5123
I removed mine few weeks ago. FYI-if you have UR underdrive pulley and use Bando Belt, use size 6PK1100
Old May 1, 2008 | 11:06 PM
  #82
Ztalker's Avatar
Ztalker
^^thanks guys.^^
switched to a 6PK1100 Goodyear belt today 25 bucks at Kragen...yikes.
Old May 2, 2008 | 07:05 AM
  #83
QuadCam's Avatar
QuadCam
I'm glad to see this thread being useful to other Z/G enthusiasts. I was starting to wonder if I was the only one who saw the value in removing htis pulley.
Old May 2, 2008 | 07:25 AM
  #84
Ztalker's Avatar
Ztalker
"less is more"
ain't that the truth?
Old Jun 30, 2008 | 03:47 PM
  #85
atlantavip's Avatar
atlantavip
has anyone taken off the idler pulley with an ati procharger setup???
Old Jun 30, 2008 | 04:01 PM
  #86
SpoilsofWar's Avatar
SpoilsofWar
Realized I never posted pics of my pulley delete. I did this when I had my engine built:
Just dont be like me and forget to torque the tensioner pully nut down. The pulley flew off during one of my post-tune pulls, lol. Luckily it landed on the charge pipe so it wasn't lost.
Old Jan 31, 2009 | 08:14 PM
  #87
06blueZ's Avatar
06blueZ
Thanks again QuadCam for the writeup. I just got around to doing this tonight. It was pretty straight forward, but my PS bracket to idler pulley bracket clearance was very tight. It took a lot of prying and actually had to use a prybar at one point to get the idler bracket out.
I cut mine like you did to get the spacer. getting the spacer piece back in place was tough too, it definetly didnt just slide in or out.
One other thing I had to do was cut down the two 17mm bolts because they seemed to bottom out in the threads with about 5mm to go. Did you have to do that?
Just have to pick up a shorter belt tomorrow and im all set. good free mod, thanks!
Old Jan 31, 2009 | 08:17 PM
  #88
06blueZ's Avatar
06blueZ
spoilsofwar i noticed that you did not replace the 2 17mm bolts. dont you think that they are more functional than just holding down the idler bracket? I would think that they go through the timing cover and into the block and also add support to the timing cover... anyway I reused mine.
Old Jan 31, 2009 | 11:40 PM
  #89
QuadCam's Avatar
QuadCam
my bolts went all the way back in.......and also the idler pulley bracket came out without an prybars or effort on my engine.
Old Feb 1, 2009 | 09:24 AM
  #90
weslutes's Avatar
weslutes
Great mod.
The idler pulley bearing can/will burn out &/or seize eventually making it a potential problem.
My idler pulley bearing burned out & seized when I had the Stillen SC. The Stillen SC uses the idler pulley as a drive pulley (another flaw in their design).
Old Feb 1, 2009 | 10:29 AM
  #91
06blueZ's Avatar
06blueZ
yea, I noticed that mine even with only 20k on it seemed slightly rough. still had a well greased resistance to it but one less thing to deal with when the car gets 100 k on it.
Old Jan 6, 2011 | 02:53 PM
  #92
G&Z's Avatar
G&Z
does anyone know the torque amont for the tensioner bolt that is upside down on bottom of the lower idler pulley?
Old Jan 10, 2011 | 07:19 PM
  #93
terrasmak's Avatar
Spacer ordered, need to change my belt anyhow.
Old Jan 25, 2011 | 10:03 AM
  #94
G&Z's Avatar
G&Z
Aight. So i just did this n it only took like 20 min. My car now feels more efficient and my butt dyno definitely notices a few hp. When i took d pulley off i spun it with my hand really hard and d dam thing only made like 2 revolutions. Super drag on d crank. My car idles better too
Old Jan 25, 2011 | 10:48 AM
  #95
terrasmak's Avatar
Did mine yesterday, my idles bearing was toast. I ended up with a 450k6 belt instead of the 455k6. If you look up the belt for a late model DE it calls for the 450K6.
Old May 5, 2011 | 10:46 PM
  #96
terrasmak's Avatar
Bump for all the people wanting to install aluminum pulleys
Old May 5, 2011 | 11:34 PM
  #97
JDMStanced's Avatar
JDMStanced
^you mean lightweight pulley?
About this pulley delete, isn't it more easier for something to move if there are many pulleys?
Old May 16, 2011 | 08:39 PM
  #98
Cide's Avatar
Cide
Did this mod today after I noticed it was missing on an 06 I had at my shop. Great mod. No draw backs.
Old Jun 23, 2011 | 06:36 AM
  #99
Star-Bucks's Avatar
Star-Bucks
I Did this Mod last night, I took about an hour. My bearing was going bad so it was a perfect mod. The belt cost $25, I used the part number 25-060435 and it fit no problem. I would like to think it picked up some power but you never now!
Old Jun 24, 2011 | 08:14 PM
  #100
Cide's Avatar
Cide
Nice to see you on here Patrick.... Enjoy the fresh tranny.. lol
