Changing Differential Oil
Old May 23, 2008 | 09:22 AM
quakerroatmeal's Avatar
quakerroatmeal
Can't you just use a funnel with an extended top and fill it up from top? That's the way I did it on the Integra at least.
P.S. Nvm that was for the transmission fluid that I did.
Old Jun 14, 2008 | 02:34 PM
gothchick's Avatar
gothchick
Originally Posted by blasian
There are suction gun/pump thingies at Autozone. I think its like $10.
+1
That's what I've been using.
Old Jun 26, 2008 | 02:44 PM
first350's Avatar
first350
here's some pics I took from my last LSD oil change.
*a good tip I read in the DIY portion...make sure the top filler bolt can be removed before draining the oil - there's a lot of heat back there and those bolts can seize.
look at how much metallic stuff is in there!
after draining the fluid, I flush it out w/ a bit of new oil...
here's what I use:
Old Jun 27, 2008 | 07:17 AM
VO...'s Avatar
VO...
Administrator
^^^ Excellent pics. Tell me, how did you like the smell?
Old Jun 27, 2008 | 01:55 PM
spddmn124's Avatar
spddmn124
make sure the fill bolt is loose first. sometimes it seizes on you its bad news when you drain the gear oil out and the fill bolt is seized... lolololol
Old Jun 28, 2008 | 03:29 AM
CSF's Avatar
CSF
i will never forget the smell
that and brake fluid
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Stevo Z
Oct 3, 2015 09:14 PM
