DIY Wire Tuck
Old Jan 9, 2013 | 04:24 PM
  #121
KingBaby's Avatar
KingBaby
Hardest Setting
Drives fine! Idles however drop and rise a lot , I'm guessing a retune since I also installed the r35 injectors!
This is as far with the tucking and mild re routing of anything lmao!
Moar
Old Jan 9, 2013 | 04:42 PM
  #122
bikinilust's Avatar
bikinilust
NICE!
Old Jan 9, 2013 | 05:01 PM
  #123
sradenton's Avatar
sradenton
[QUOTE=KingBaby;10006546]Name:  89E63436-BEB6-40A5-8C8F-53254B33A396-1212-00000061F7E9891D.jpg
Looks Good KingBaby
Old Jan 9, 2013 | 05:50 PM
  #124
bikinilust's Avatar
bikinilust
Originally Posted by sradenton
Can you explain your problem alittle more and what you've done in the past to bleed your coolant? Have you tried drilling a bleed hole in the thermostat and if you have nismo or mishimoto remove the little plug so it can constantly flow a little and air doesnt get trapped at the thermostat? Old trick in the V8 world,
Procedure that I follow:
Install lisle coolant funnel
http://www.amazon.com/gp/aw/d/B001A4...086194-8436936
Raise front of vehicle or leave on flat ground.
Slowly pour coolant into funnel, allowing air to escape easily, till full.
Open bleeder near firewall to release trapped air, then close it.
Turn on vehicle, idle around 1500 rpm to warm up faster.
Rev engine to 3000 rpm every once in awhile and watch for bubbles in funnel
Once starting to get warm, turn on heater to full heat
Then again open bleeder at firewall to release trapped air.
Then repeat above till thermostat opens and there isnt any more bubbles in funnel
Old Jan 9, 2013 | 06:04 PM
  #125
bikinilust's Avatar
bikinilust
What is the downside to drilling a hole in the thermostat?
Longer warmup?
Old Jan 9, 2013 | 06:15 PM
  #126
KingBaby's Avatar
KingBaby
Hardest Setting
I would believe not as severe as removing it as I did...
Old Jan 9, 2013 | 06:24 PM
  #127
sradenton's Avatar
sradenton
Longer warmup?
That's the same way I bleed my coolant system and air is still getting trapped?
I hope I don't have problems with trapped air after changing the pipes.
Drilling a small hole, lets small amount of coolant to bypass and won't allow air to get trapped at the thermostat. Yes!!! I would think is would increase the warm up time, but not much. I was thinking about your idea of putting a bleed valve on the pipe. Get idea!!! But thinking it might pull air in if you bleed while the engines running since its low.
Old Jan 10, 2013 | 12:37 AM
  #128
bikinilust's Avatar
bikinilust
I can see how it being a low point could be an issue, but if the front of the vehicle is raised the issue may be less. Or if not, on flat ground, being left open long enough would eventually allow coolant to flow out of the bleeder (exp. Gravity bleeding brake fluid)
Old Jan 10, 2013 | 12:42 AM
  #129
bikinilust's Avatar
bikinilust
Why would you remove the thermostat altogether? I can understand that you may want lower coolant temps but wouldn't that mean you will never reach proper operating temps?
Old Jan 10, 2013 | 01:34 AM
  #130
KingBaby's Avatar
KingBaby
Hardest Setting
No no, the thermostat just stages warmup for the block then opens when too hot! Removing it all together just eliminates that closed loop. So from startup it's open creating cooling from the start which makes it longer to get to operating temps!
Old Jan 10, 2013 | 07:23 AM
  #131
bikinilust's Avatar
bikinilust
For your application why would you need this ?
Old Jan 10, 2013 | 08:26 AM
  #132
litoflow's Avatar
litoflow
If you drift and maintain your vehicle regularly, you may want to do your coolant line tuck in a slightly different manner than what everyone else is doing. The Coolant line tuck makes bleeding the coolant a *****....air typically gets trapped around the thermostat....or at least this has been my experience with the DE's
there is a bleeder in the back of the engine for coolant. did the same to this z as my twin turbo z I drifted for a year..never had a single issue thanks for the tip though.
Old Jan 18, 2013 | 06:45 PM
  #133
litoflow's Avatar
litoflow
better pics of the tuck in from far away i guess. Do not mind how dirty she is. lol
Old Jan 18, 2013 | 07:54 PM
  #134
sradenton's Avatar
sradenton
Looks GREAT litoflow
Old Jan 18, 2013 | 10:52 PM
  #135
KingBaby's Avatar
KingBaby
Hardest Setting
Indeed
Hey litoflow did you replace you windshield yourself?
It's not a need thing for me. It was a bad thermostat, the nismo one was not for direct fit for the 07/08 and it's not my DD so I cut it out!
Old Jan 19, 2013 | 08:08 AM
  #136
litoflow's Avatar
litoflow
thanks man! finally looking like a car lol
Indeed
thanks man!!.. Na i paid a company to come out and do it. Too cold outside for me too plus i did not have the tool for it but now i know where to buy it
Old Mar 4, 2013 | 05:57 PM
  #137
Neu Era's Avatar
Neu Era
Looking great!
Old Mar 4, 2013 | 07:10 PM
  #138
litoflow's Avatar
litoflow
^^Thanks man. i did little things here and there, took the alternator ground wires and hid them throw the bottom, took the emission crap off that hangs off the plenum so it looks a lot cleaner. and the speaker for the alarm on the driver side i took it off so it doesnt look like i didnt do nothing haha. when i get a good pic i'll post
Old Mar 5, 2013 | 07:21 PM
  #139
Esser's Avatar
Esser
I wish i had the patience for this! good work
Old Sep 20, 2013 | 01:02 PM
  #140
The_NEXT_steP's Avatar
The_NEXT_steP
this is not something you can jump in and tackle in one sitting. i am eager to start this at some point...the end result looks great.
