will any year vq35de fit wire harness?
Old 04-24-2018, 04:32 AM
Eric Pipp
Eric Pipp's Avatar
Default will any year vq35de fit wire harness?
I recently bought an 03 350z 6mt for dirt cheap and it has lifter ticking noises. I think I want to just swap out the engine I have with a lower mile vq35de to make it easy, this way I won't have to worry about the wiring harness, my question is, if I buy any other year's model engine such as an 05 vq35de will all the connections work properly? I would assume the rev-up engines would be different, but I have found no information on the wiring side of this topic.
I searched the forum for this answer and couldn't find anything (I may have used bad keywords for this, if so I apologize!)
Old 05-02-2018, 05:00 AM
Bernardo Z33
Bernardo Z33's Avatar
From what I know and you may also know this is that anything that has to do with an HR is out of the water. Nothing will work from an HR. So now were left with a revup vs non revup. If its an 05 then I think only the 25th anniversary 6MT had the revup. From what I've seen and read you can swap a revup into a nonrevup. Wiring harness wise I think you can run the nonrevup wiring harness with a revup engine but you have to do some wiring and if you don't it'll run like a normal nonrevup. Don't quote me on this But I think I red about that somewhere. In all honesty to make it easy for you i'd suggest just getting the nonrevup harness just to save you headaches. I believe if you don't plug in the additional cam sensors your revup will run like a normal DE with the DE ECU and harness.
Here is a link in case I am completely wrong. To make it easier try searching next time. There are hundreds of posts talking about this
https://my350z.com/forum/engine-and-...lete-swap.html
Old 05-02-2018, 05:04 AM
Bernardo Z33
Hope this helped.
Old 05-02-2018, 05:46 AM
vegasanthony
vegasanthony's Avatar
03-04 is the same engine harness..no wide band 02 sensors..
05 non anniversary is the only year the harness is specifically for a non revup with wideband capabilities precat
2006-07 is a revup with wideband precat and extra cam sensors
The 05 and
The rev up engine harness has different pinouts from the harness
To the ECU..
in your case since you have an 03 ECU the 05 engine harness would not work well it would be sending signals to the wrong pins on the ECU from the pre cat O2 sensors..
So you can buy the 05 not revving up but you have to use the 03 harness
Old 05-02-2018, 10:40 AM
vegasanthony
The 05 harness has these 6 prong connectors for 02sensors/ airfuel sensors
Old 05-04-2018, 02:02 AM
Eric Pipp
Eric Pipp's Avatar
Very helpful information guys, thank you! Essentially if I just stick with an 03 or 04 that will be the most simple for swapping (just unplug everything on the old, plug back in everything on the new). Do you have any knowledge on if the G35 engines will swap as easily?
Old 12-14-2018, 08:29 PM
Adam_ant442
Adam_ant442's Avatar
Default 03-04 harness the same??
(Each car is a 6 speed)So I have an 03 car that doesn't have an engine in it I recently bought about a month ago I just got A 04 car 2 weeks agoThat runs and drivesSo the differences I have found between the 03 and 04 harness in the 04 car it has vdC button In my 03 car does not but has A TCS Button in place of It I have Read that if left disconnected it just deletes it Which is straight because this is going to be a drift car My question is Should I run the 04 eCU with the 04 harness and 04 engine in my 03 car will it plugged in all the same to the dash harness??? Another difference I have found is the 03 car has a different "ABS block" (silver thing that all brake hardlines connect 2) Then the 04 car and has different wires and connectors that come from the ABS block in my 04 car then my 03 car I was thinking to just swap the ABS block from 04 car to of 3 car to eliminate any problems do you think this will work
Old 12-05-2022, 04:01 PM
EvtPhil
EvtPhil's Avatar
I’m having the same problem. I just swapped a vq35de from an 05 with the harness into my 04 G35 sedan and now I can’t get any communication from the computer. The car is cranking but it won’t start. I plug my scanner up to the OBDII port and it wouldn’t read anything.
Old 12-05-2022, 04:25 PM
bealljk
bealljk's Avatar
Received 1,282 Likes on 1,007 Posts
EvtPhil -
Check the easy stuff first … basic principles - Air, spark, fuel … make sure you have fuel pressure and injector harness is plugged in, make sure your coils are pluged in, new spark plugs? Maybe do the throttle body reset.
so you may have more than one problems here - VegasAnthony’s post #4 is quite possibly the best description of the years and what each has - make sure you dont violate any of those constraints.
You may have a NATS (nissan antitheft) that isnt allowing the car to start - are familiar with NATS? Is your security light solid red (Usually a good indication that NATS is preventing the car to start).
You may have a damaged harness in that you damaged your CAN communication - thus not allowing you to pull OBD2 codes.
The car will crank until the ECU recognizes the position of the crank shaft and cam shaft (typically the passenger side - I believe). So if the crank shaft and cam shaft position sensors are faulty, disconnected, and/or damaged wiring the ecu wont send spark event.
alx954
Wanted
04-04-2011 05:38 PM
Mr_pharmD
05-09-2009 04:06 PM
Quick Reply: will any year vq35de fit wire harness?
