ACT clutch/flywheel installed
Old Nov 8, 2008 | 08:39 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Post ACT clutch/flywheel installed
45k milies, somehow my pilot blushin broke. So i decided to replace clutch/flywheel as well. I read many good things about ACT brand, so why not?
Flywheel is very light (13lbs) and ACT heavy duty clutch feels very strong. The first day when i picked up the car, i stalled couple times, untill now i never stall the car yet? But it doesn't mean that i'm already use to it.
Clutch pedal feels really smooth and lighter than OEM, i replaced the clutch line/fluid as well. Trust me, it is very easy to drive on street. And there is chatter @ 1500~2000 and high gear in/low speed, but i don't mine
I'm still driving very carefully, shift around 3500 ~4000 rpms, i didn't even try rev-up when gear is in netual. (I can't wait untill it break-in ) It is perfect setup for my driving style.
Act offer Prolite/streetlite flywheels and heavy duty/6punk solid or sprung clutch. Prolite clutch is more lighter than streetlite ( 16 lbs ) and 6 punk clutch will be good choice for FI guys.
* note: it didn't come with an alignment kit, so who willing to replace clutch/flywheel yourself, i do recommand get the alignment tool seperately from your local auto shop.
I bought my parts from adam@z1. If you have any questions, shoot PM to adam to get an answer https://my350z.com/forum/members/113...rformance.html, very heplful guy.
-JLee stay tuned
Old Nov 9, 2008 | 01:12 PM
350z-Jim's Avatar
350z-Jim
If you are using an organic disc then break-in is only 200-300miles if you are using any of the pucked designs then there is no break in period just hammer it right off the get go.
Even with that said, organic discs will have a long life even with very little break in period of just a few miles. What disc are you running?
Old Nov 9, 2008 | 05:38 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
^organic clutch disk, heavy duty pressure plate
Old Nov 9, 2008 | 09:00 PM
kramykram's Avatar
kramykram
Congratulations on the upgrade. Your never know what a diff the flywheel makes till you drive with a lightweight.
Old Nov 10, 2008 | 06:53 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
^ thanks, too bad that i'm going to store my car today, so i won't be finish break-in period time. But Still excited, can't wait untill winter is over.
Old Nov 11, 2008 | 09:22 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
Some PM's asking me how pilot blushing got broken, i have noidea. Here is picture that request
Old Nov 23, 2008 | 09:05 PM
drewk's Avatar
drewk
I just installed the ACT clutch and flywheel and SS lines. There is ALOT of chatter in first gear. Im not used to it... when I disengage its like the car is going to shut off because its shaking so much. Is this normal? What should I do?
Old Nov 24, 2008 | 06:53 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
^ yes, it is normal. You will get used to it.
Edit: here is testing video i took.
http://vids.myspace.com/index.cfm?fu...deoid=46848879
I had to put high gear @ low speed to catch that chatter (or gear rattle ).
Old Nov 24, 2008 | 08:39 AM
drewk's Avatar
drewk
This might sound weird, but there is LESS chatter when I start in second gear and rev really high. Thanks for the vid, Im at work, I might have to watch it when I get home. And maybe I can make my own and post it.
-Andrew
Old Nov 24, 2008 | 08:54 AM
t0mills's Avatar
t0mills
-Andrew
Just a FYI,
The chatter that you are getting (shaking when taking off) is caused by the springs in the clutch disk.
They are put there to dampen vibration, similar to the way that our OEM Dual Mass Flywheel does.
When you are slipping the clutch, to take off, you are putting enough tension on the disk to load the springs. It sounds like you may not be releasing the clutch fast enough, thus causing the springs to overcome the amount of tension that you are placing on the disk, and unload. Then they will load again, and unload. That's the shaking that you are feeling, the springs loading and unloading.
To remedy this, try taking off a little more aggressively. Once the springs in the clutch hub load, you should be at the point of fully releasing the clutch pedal.
-Tim
Old Nov 24, 2008 | 09:58 AM
drewk's Avatar
drewk
^ Thanks, I did realize that taking off more aggressively at a higher rpm lessens the chatter. Thanks for the tip... appreciate it.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
