The Official LS Swap Info/Questions Thread
Pictures?
Good info for the fuel setup Logan,, That will help out a lot of people.. I have/will have mine setup just like that also..
On a side note, I really hope my shifter is not ****ed up like yours 04.350z,, If it is I am going to be pissed. But if you work out the issues, I will be hitting you up for sure
He used the 350z clutch and flywheel IIRC.
Excuse my ignorance, been interested in LS swaps recently and just been reading as much as I can. Regarding the starter, what are you interested in, just where he relocated it from the spot on the Z tranny? Or how he attached the new one in that spot? Not sure what the usual procedure is. TIA
Do you really have to use this rigged setup for the clutch master cyclinder from sikky? The washer hole is a bit too big, the outer size is too small, and this extention is just retarded. Not to mention the bajo bolt dosent thread into the cyclinder that came with the chasebays line kit. Wtf!
mine threaded right in. the bleed line threads in, the line that goes to the master cylinder has a pin in it on the slave cylinder which sits around the input shaft. knock out that pin, remove the old one, and put in the new on (slips in) and replace the pin. however, the line that goes to the master has the factory ls size restrictor which causes a pressure loss on a 2-3 upshift (a common ls1 problem) your best bet is to either buy a line with a 1/8 hole, or drill your restrictor out. mind, your best bet is to do it now, because if you ever want to do it later, your trans has to come out. and your trans bellhousing is too big for your z trans tunnel so it makes the process a much bigger pain in the *** than a imple tranny drop.
yeah they said thats all i needed too but that wasnt the case.
for everyone waiting on a fix i am working on a fix now but dont want to post anything until i get it fully figured out and that it will be a real fix to the junk sikky shifter.
Well thats good that you could order one. Every dealer in Mn said they were on indefinite back order. I ciuldnt even find one out of state. I got lucky on LS1tech. Well i had to retap the sikky master cyclinder adapter plate because they had 2 different size bolts in it and thread pitches. They said they were gonna check into it and i never heard from. Justin again. So I retapped that and the wilwood cyclinder. Finally ready to put the rest of the parts in..that shifter better work when i get it running! Thats all i gotta say!
That's what i said
Some info I just found out about the shifters:
"If you decide to run a GTO trans with an f-body shifter (or vice versa) you will need to run the f-body shift ball receiver on the end of the shift shaft or you will not be able to fully engage all gears"
I think you have that backwards. You need to use a gto shift cup, otherwise you only have 1,3,5 gears. The camaro one is too short for the way sikky made their shifter.
Question, what did everyone do with the fuel breather line, i believe thats what it is. The line that runs up with the stock fuel feed line. Do i need to do anything with that line or just leave it open?
Gto "style" shifter = sikky shifter
Camaro shifter + Camaro shifter block = success
Gto shifter + gto shifter block = success
Camaro shifter + gto shifter block = fail
GTO shifter + Camaro shifter block = fail
So therefore:
Sikky shifter (gto style) + GTO shifter block= success!!
Sikky shifter (gto style) + Camaro shifter block = fail
Disclaimer:
I don't have my parts yet so I cannot validate this.
any of you guys running a ls swap delete the abs and still able to use a speedo? as in know the pulses of the nissan sensors so a aftermarket speedo can be used. im about through with my POS and all the problems im having about to delete everything i dont use and convert to a mechanical TB >.<
