Engine Swaps For all your engine swap experiences, ideas, questions, & more..
The Official LS Swap Info/Questions Thread
Old Nov 20, 2012 | 04:50 PM
  #1061
sportbiketed's Avatar
sportbiketed
Start here, ls1 tech, zilvia, hybrid z and craigslist. I just bought a swap kit from Quamen for $1200.
Old Nov 20, 2012 | 05:57 PM
  #1062
Gozirra's Avatar
Gozirra
Thanks, I appreciate the help. Thats a kickass deal
Old Nov 20, 2012 | 06:51 PM
  #1063
mhammel20's Avatar
mhammel20
i have an ls1 short block for sale all yours!!
Originally Posted by Gozirra
If only I knew where to even start. Saving money is all I can do
Old Nov 21, 2012 | 01:17 PM
  #1064
Gozirra's Avatar
Gozirra
Hah ok how much sir
Old Nov 21, 2012 | 04:36 PM
  #1065
mhammel20's Avatar
mhammel20
text me ill give you details 317-690-4781
Hah ok how much sir
Old Nov 23, 2012 | 09:20 AM
  #1066
Royal_T's Avatar
Royal_T
Originally Posted by sh0rtys463
So I asked about this on the LS forum and thought I'd post up here to see if I get anymore help. When the car gets up to around 200-205 degrees the coolant fills up the overflow tank and bubbles over. The line from the TB connects to the overflow tank and this is where I think my problem lies. I believe it should leave the TB and go back to the radiator and the hose by the radiator cap should run to the overflow tank. Correct? I don't have a spot to run the hose from the TB so can I just cap it off? I've seen that people bypass the coolant to throttle body but I would still need a place for that line to go if I can't cap it off. Any suggestions? This is the spot Im talking about:
This is how I route mine..
Old Dec 1, 2012 | 05:02 AM
  #1067
Dopavash's Avatar
Dopavash
Has anyone done the LS swap into an Auto car? I'm still hunting a donor car and I've found lots of good deals, but they're auto. If I'm wanting to end up standard, you guys think there will be any big obstacles?
Old Dec 1, 2012 | 05:27 AM
  #1068
Quamen's Avatar
Quamen
Are you saying you have an auto Z or the LS cars are auto?
Old Dec 1, 2012 | 08:48 AM
  #1069
Dopavash's Avatar
Dopavash
The Z is auto, the LS is stick. I'm wanting to do the swap, starting off with an automatic car, ending up with a stickshift LS car.
I'm assuming there wouldn't be much difference in doing the LS1 in a G35 instead of a Z, correct?
Old Dec 1, 2012 | 09:20 AM
  #1070
Quamen's Avatar
Quamen
It shouldn't be to hard but don't be surprised that you will have to cut holes in your car for the pedal and master cylinder. Shifter may require some clearancing as well.
Old Dec 1, 2012 | 09:47 AM
  #1071
sh0rtys463's Avatar
sh0rtys463
My g35 was auto and now has ls1 and t56. It's just about up and running so it's possible.
Question for you guys. Where did you wire the reverse lights off of the tranny?
Old Dec 1, 2012 | 10:01 AM
  #1072
Dopavash's Avatar
Dopavash
I guess I was more worried about wiring issues. I understand that I'll need the mechanisms to run the clutch, and the interior pieces from stick shift Z or G. I'd like to retain as much 'stockness' of the car as possible when it comes to switches and dash pieces etc. I've read about the difficulties on the Tach and the Nissan CanBus system, but I'm pretty ignorant when it comes to wiring. Well, more ignorant than the rest of it! Heh.
Also, I understand that, if they motor is put close enough to the firewall (like with the Fueled Racing mounts), and you're running a GTO shifter setup, the shifter ends up in the correct place. Is this correct? I also understand that, from the bellhousing to the Shifter on the T56 tranny is is something like 34 or 35". I believe the new Comaro TR6060 setup ends up being the exact same length. Anyone know of any reason I can't run that transmission instead? I think Royal T was going to do something similar to this.
Old Dec 5, 2012 | 04:24 PM
  #1073
sh0rtys463's Avatar
sh0rtys463
Anyone want to help me out with where you wired the reverse lights off the trans?
Old Dec 5, 2012 | 05:42 PM
  #1074
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Anyone had or heard of experience with Z fever in FL for a Ls swap?
Old Dec 7, 2012 | 10:25 AM
  #1075
Cass007's Avatar
Cass007
I've heard of Z fever in the F/I forums, but not for an LS swap. Maybe put up a thread in the SE regional forum and see if the locals can help you out.
Old Dec 7, 2012 | 10:29 AM
  #1076
Cass007's Avatar
Cass007
I got my LS2 off of ebay from LKQ... you could start there.
Old Dec 8, 2012 | 06:34 AM
  #1077
Quamen's Avatar
Quamen
II can sell you a built LS1 also!
Old Dec 8, 2012 | 09:45 AM
  #1078
QTB's Avatar
QTB
I have all the internals to an ls2 if you can dig up a block.
Old Dec 8, 2012 | 11:33 AM
  #1079
Quamen's Avatar
Quamen
The Z33Art drag chassis is officially sold! Luckily someone with more than enough money bought it and will be putting a turbo LS3 in it... of which they are going to hire me to mount for them!
Old Dec 9, 2012 | 03:48 PM
  #1080
bbs350z's Avatar
bbs350z
^yes! its in good hands with mr miller my friend. ps ill take that finders fee
