Engine Swaps For all your engine swap experiences, ideas, questions, & more..
The Official LS Swap Info/Questions Thread
Old Aug 18, 2015 | 11:25 PM
  #1641
armt350z's Avatar
armt350z
The standalone does not alleviate you from the harness issues, if anything it will exacerbate them since it will require splicing entire harnesses. In general, there are a few harness manufacturers that are reputable.
Your probably looking at $3000 for a standalone and install. add another 600-1000 on tuning.
For that money you could get a full LS2 or LQ9 pullout engine with all the front accesories, harness and ECU and be further ahead.
Old Aug 19, 2015 | 01:11 AM
  #1642
Pengu's Avatar
Pengu
Thanks for your help! I'll be keeping both ECU's then instead and save myself the money.
Old Aug 19, 2015 | 01:12 PM
  #1643
Justin100's Avatar
Justin100
How much is the shop charging you? Why don't your just buy all the tools and do it yourself?
Old Aug 19, 2015 | 01:18 PM
  #1644
travlee's Avatar
travlee
Master
maybe he doesnt feel comfortable doing it
Old Aug 19, 2015 | 01:35 PM
  #1645
Pengu's Avatar
Pengu
The shop is still doing some research, I've dealt with Hills Garage before and they like to give as close to realistic quotes as possible.
I am not comfortable doing the swap as I've mentioned before it. Removing the engine maybe, I've done some reading and think I could handle it and was considering doing this to save some money. However, I do not believe I could put an entire different engine in and am more comfortable paying for a clean job.
Old Aug 19, 2015 | 02:05 PM
  #1646
Justin100's Avatar
Justin100
Id encourage you to do it for yourself because most likely the shop will charge you like 5 grand and with 5 grand I can buy a beater and all the tools online if I am missing something just drive my beater to the nearest autozone or O'Reilly auto parts lol
I like to know that if my car breaks down I know exactly what happened. After the swap if your car breaks down th shop can come up with some bs explanation to make you spend more money
Old Aug 19, 2015 | 02:09 PM
  #1647
Pengu's Avatar
Pengu
I just don't feel comfortable doing the swap. I am not capable to me machining parts or any other necessities. God knows how long the car would actually be out of commission if I were to do it lol. Plus I would not trust myself with wiring at all lol. I can do basic wiring but never even messed with a cars before.
Even if I did want to do the swap, I don't have a garage or carport, just a gravel driveway lol.
Old Aug 19, 2015 | 02:12 PM
  #1648
Justin100's Avatar
Justin100
I know a shop next to my house that is a high performance Honda shop they have a dyno and work on 1000 hp cars.
Everytime I go to their shop they're give me terrible advice on fixing just about anything
Like in the past when my car was misfiring they said change all spark plugs without even reading the codes
I took it to autozone to have the codes read and cylinder 1 was misfiring so I looked it up and replaced 1 ignition coil problem solved....
If something happens to your car your at the mercy of the shop.....
Old Aug 19, 2015 | 03:59 PM
  #1649
Classy's Avatar
Classy
I would trust hills garage, I hear a lot of guys using them with nothing bad
Old Aug 19, 2015 | 04:35 PM
  #1650
Pengu's Avatar
Pengu
Yeah, they tuned my last Z and did some other work including 4.08 gears and such. The only time I've ever been over quoted and paid less than what I was told. They truly are the best shop I've been too. The only downside is they're so busy now it's takes a bit longer to get a response. Good news is I'm not in a rush yet as my goal is to start in February.
Thanks again everyone for the replies!
Old Aug 19, 2015 | 04:52 PM
  #1651
Justin100's Avatar
Justin100
http://m.ebay.com/itm/CXRacing-LS1-T56-Transmission-Swap-Kit-Header-Downpipe-Oil-Pan-For-Nissan-350Z-/251786385730?nav=SEARCH
Cxracing has the ls swap kit also Cheaper than sikky and fueled racing... Might want to try this out..
Old Aug 19, 2015 | 05:42 PM
  #1652
travlee's Avatar
travlee
Master
motor mounts i wouldn't trust
Old Aug 20, 2015 | 04:49 AM
  #1653
Classy's Avatar
Classy
Honestly, the mounts look good, actually the whole thing looks good. You would probably need a hockey puck or a like style bushing in there but I might be tempted to try it out
Old Aug 20, 2015 | 06:04 AM
  #1654
armt350z's Avatar
armt350z
I'm with travlee on this one. The C channel mount is structurally one of the weakest forms. They are especially prone to lateral torsional buckling. Any torque applied to the mount will make the mount want to twist instead of bend like a rectangle or tube.
Also that plate with the 4 holes... I could see that interfering with several front accessory kits which would be one more hassle I wouldn't want to deal with.
Old Sep 9, 2015 | 03:19 PM
  #1655
BikesNZs's Avatar
BikesNZs
I've been working on the wiring part of my my swap and pretty stumped. I am using a PSI harness, http://secure.ultracart.com/catalog/PSI/HAR-1013.html
I ditched the stock engine wiring harness and ecu as well. Basicallly, the PSI harness is a stand alone harness and I need splice it into the remaining factory wiring in order to get power and a few other things hooked up. I think I need to splice the new harness into the wires for this plug.
Problem is I have no idea what this plug went to or what its for and I cannot find a pinout for it. I have searched all over the interwebz and gone through the factory service manual and nothing. Does anyone have any idea what this plug is for? It is located where the stock ecu is mounted but doesn't plug into it.
This is a PDF of the instructions for my harness. Maybe someone can point me in the right direction to properly hook it up. Mainly just having an issue with the "underdash wires" on page 9.
http://www.psiconversion.com/tech_ar...structions.pdf
Old Sep 11, 2015 | 10:55 PM
  #1656
armt350z's Avatar
armt350z
If I remember correctly thats the super multiple junction plug. I'm at work right now so I don't have my reference. When I get home I'll look which wire I tapped off that plug from my GM harness. You can reference that plug in the FSM under electrical/driver information systems and electrical/power supply.
Old Sep 12, 2015 | 10:00 PM
  #1657
blAk mAx's Avatar
blAk mAx
Old Sep 13, 2015 | 11:40 AM
  #1658
Classy's Avatar
Classy
I always wanted a LS swapped 370
Old Sep 19, 2015 | 03:59 PM
  #1659
blAk mAx's Avatar
blAk mAx
im also looking at my engine wiring harness.. i have the psi harness
Old Sep 24, 2015 | 11:48 PM
  #1660
Justin100's Avatar
Justin100
I would do an ls swap myself because this forum is so extensive and many people have done it so their is no surprises. can find all the info on this forum.
i would only have a shop do the swap if their was tons of uncertain aspects and not a lot of information.
i saw this video.
