Engine Swaps For all your engine swap experiences, ideas, questions, & more..
My 2jz swap
Old Aug 14, 2017 | 11:40 AM
Blurvision's Avatar
Blurvision
With a welder and a dream! Keep it coming.
Old Aug 18, 2017 | 04:07 PM
chase z's Avatar
chase z
pretty much . Now I have to decide to paint all the engine parts or just say fu*k it and start finishing this up
Old Aug 18, 2017 | 06:39 PM
chase z's Avatar
chase z
Took a few hours off from working on the car on my off time to make a shelf to free up so room
I all so put the wideband in the oem volt gauge pod idk if i like it but iam not a aftermarket pod kind of guy
I still have to get a new oil pressure gauge to replace the oem one.
Old Aug 25, 2017 | 01:11 PM
chase z's Avatar
chase z
Making the catch can in the space I had to cut out the damaged cores.
Mocked up the catch can. I still have to weld on the fittings and the drain bung
Old Sep 1, 2017 | 03:33 PM
chase z's Avatar
chase z
Cjm parts to convert it to return style fs
Installing nut surts
Mounted now to paint it
Old Sep 4, 2017 | 01:00 PM
chase z's Avatar
chase z
Got a few things media blasted and painted
And moved the battery into the trunk. With a 200 amp breaker
Old Sep 9, 2017 | 03:48 PM
chase z's Avatar
chase z
Had to move that feed for the heater core. I didn't have that pipe on when I made my down pipe and the end hit the dp so I had to cut it off and then move it to the back
Old Sep 10, 2017 | 11:20 AM
chase z's Avatar
chase z
Old Sep 22, 2017 | 10:23 AM
chase z's Avatar
chase z
Old Sep 26, 2017 | 01:55 AM
JetBoost's Avatar
JetBoost
How much money do you have into your swap?
Old Sep 26, 2017 | 03:08 PM
chase z's Avatar
chase z
my number wouldn't reflect vary well. Lots of the stuff I had and or sold other parts to get the new parts. I had the motor. Sold my 6266 that payed for most of the 369sxe.
I sold my fsr cast maifold that payed for the new top mount .
I sold my r154 with stage 5 clutch that payed for all but $325 of the cd009 adaptor and twin disk clutch.
I had the fuel line and the fuel cell
payed 500 to have my wiring harness adapted to cd009 and added lq9 coil on plug wiring and a few other things.
but when I have time I will go throw everything and give u a real number.
Old Oct 2, 2017 | 05:52 AM
Mike Pickard's Avatar
Mike Pickard
Default Driveshaft
How did you go about your driveshaft for this build? Custom or if not then where did you buy it?
Old Oct 2, 2017 | 06:25 AM
KingBaby's Avatar
KingBaby
Hardest Setting
Awesome stuff
Old Oct 7, 2017 | 11:23 AM
chase z's Avatar
chase z
it's has to be custom. i made the motor mounts and trans mounts so no one would have a off the shelf driveshaft for me.
Old Oct 7, 2017 | 11:27 AM
chase z's Avatar
chase z
Old Oct 8, 2017 | 08:33 AM
chase z's Avatar
chase z
Not bad Clearance for a 4in turbo back to the tomei ti exhaust. Still have to add a hanger which will bring it up a little as well.
Old Oct 14, 2017 | 09:07 PM
vinniePOOH's Avatar
vinniePOOH
Thumbs up
This is a SICK build! I wish you were my neighbor! I want to 350JZ mine!
Old Oct 17, 2017 | 02:01 PM
  #38
chase z's Avatar
chase z
thanks man. U never know i could live just down the road.
Old Oct 17, 2017 | 02:11 PM
  #39
chase z's Avatar
chase z
Exhaust is all welded up and hanger installed u can't even tell there is a 4inch exhaust under there.
Old Oct 19, 2017 | 08:57 AM
  #40
chase z's Avatar
chase z
Getting all the wiring wraped up. And I orederd my drive shaft it should be here Monday.
