Engine Swaps For all your engine swap experiences, ideas, questions, & more..
My 2jz swap
Old Jul 25, 2017 | 03:24 PM
chase z's Avatar
chase z
Default My 2jz swap
Pullinh the vq
Motor out
192k vq
Saying goodbye to the vq
Old Jul 25, 2017 | 03:39 PM
chase z's Avatar
chase z
The gte vvti
2j with the new bw369sxe turbo
Thw greddy intake welded to the stock runners with a custom 12 injector setup for staged injectors
The maverick motorsports jz/vq twin plate clutch
Testfitting the motor
Test fitting with mainfold and turbo
Welding up the mounts
Old Jul 25, 2017 | 03:44 PM
chase z's Avatar
chase z
Bc vvti 272 cams.
The mounts done and mounted just have to paint them
Welded on the wastegate flange
Old Jul 25, 2017 | 04:36 PM
chase z's Avatar
chase z
Cuting out the oem tac
Test fitting the tac
Tac
Old Jul 27, 2017 | 04:20 AM
jksstar's Avatar
jksstar
looking good
Old Jul 27, 2017 | 08:18 AM
iideadeyeii's Avatar
iideadeyeii
That gauge fits perfect in there.
iideadeyeii
Oh ya...the rest is cool too
Old Jul 31, 2017 | 05:08 PM
chase z's Avatar
chase z
Thanks lol here is some more progress. Welded up the 4in down pipe . I know my tig shills still need some work
Old Jul 31, 2017 | 06:41 PM
SamEast's Avatar
SamEast
Man this is fantastic!
Old Aug 3, 2017 | 05:23 PM
chase z's Avatar
chase z
thanks man.
Old Aug 3, 2017 | 05:33 PM
chase z's Avatar
chase z
Makeing som templates to make the fuel cell that will go in the oem battery location
The huge fuel pump and pre filter
My shitty aluminum welds.
Testfitting the cell
Checking for leaks . It hold just a tad over 3 gallons.
And this is the cell for the large injectors 2200cc that will only be on during boost and they will be using e85
Old Aug 6, 2017 | 12:23 PM
chase z's Avatar
chase z
Monting the ac condenser to the radiator
All was going good tell this happened. I was drilling the bracket and by backing piece of aluminum slipped and i puched a hole through 2 of the cores. Sucks.
So i cut off the bad portion and welded up the core. So with the extra room there i will make a oil catch can in that space.
I had to cut up the rad support to make toom but it all fits tight now
Heres the cut up rad support
Old Aug 7, 2017 | 11:11 AM
iideadeyeii
DIY work like this is what separates the men from the boys. In my experience if you can do stuff like this you can work on almost anything house/motorcycles/boats etc.
What are you using to weld the aluminum?
Old Aug 7, 2017 | 12:06 PM
travlee's Avatar
travlee
Master
i remember when i first saw this thread pop up, just going by the title i was thinking dreamer noob post.... glad to see it wasnt.
great job OP
Old Aug 7, 2017 | 03:00 PM
chase z's Avatar
chase z
Thanks ! I have a cheap eastwood tig 200ac/dc
great job OP
Yea I don't blame u man lots of people post about doing things in the car world with out the means or patience to get it done. Other then the wiring harness everthing on this car will be done by me.
Old Aug 7, 2017 | 03:27 PM
chase z's Avatar
chase z
The old jz car a e36 with a 2j in it
The way it sit's now
Old Aug 8, 2017 | 07:25 AM
iideadeyeii
When I installed a T8D in a Geo Metro I just ran the whole engine harness/cluster/Ignition from the Kia and kept all the Geo stuff.
I didn't have to splice anything, but I'm sure you want something that works with factory gauges.
Old Aug 9, 2017 | 04:34 PM
chase z's Avatar
chase z
I got a plug and play harness allready.
Old Aug 11, 2017 | 03:06 PM
chase z's Avatar
chase z
Cuting off the feed and return and putting on an20 fittings and making it a duel pass rad
Old Aug 13, 2017 | 01:48 PM
chase z's Avatar
chase z
Had to shorten the shifter bracket and iam not the best at welding cast aluminum but it will work.
