Engine Swaps For all your engine swap experiences, ideas, questions, & more..
Swapped non revup not running
Old Mar 19, 2021 | 03:43 PM
ToothlesstheZ's Avatar
ToothlesstheZ
Default Swapped non revup not running
I just recently built my non revup vq35de the list includes:
Wiesco pistons 11:1 compression
Manley H-beam rods
L-19 APR head studs
APR main studs
new oil pump with boundry billet gear
All new bearings main and rod
Comsic head gaskets
All new oem gaskets
Block has been decked and bored(stock bore still)
everything balanced
JWT light weight flywheel and new OEM clutch
Anyways. motor was swapped and does not run right. It will start and crank over really rough. Will idle for about 30 secs, can't rev past 1k and dies. It was getting oil pressure and now is not getting any according to the guage. I changed the spark plugs and they were soaked in fuel and were black. So I think its compensating and adding more fuel making it run rich. Any ideas? My last idea is it could be the flywheel aligned wrong.
ToothlesstheZ
Default Here this the video of the car starting
Old Mar 20, 2021 | 06:24 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Codes?
Old Mar 20, 2021 | 08:02 AM
ToothlesstheZ
Originally Posted by MicVelo
Codes?
Yeah thats the crazy thing no codes at all.
Kspinazzola
Sep 9, 2024 08:52 AM
boostedforlife
NA Builds
May 13, 2011 08:39 PM
jdf28045
Feb 13, 2009 12:32 PM
Jokestrap
Nov 24, 2005 02:50 AM
se-r / gti-r
Nov 19, 2005 07:47 AM
