FS: full long block Cosworth vq35 bottom/PORTFLOW heads!!!
Hi,
I'm selling a motor for a buddy!
1. Cosworth VQ35DE (low compression 8.8:1), Ported and Polished Heads, and Cosworth Cams ZK2 Grind – Basically a complete long block. The motor, heads, and cams have less than 7,000 miles on them…I would like to sell the complete long block as all one piece…asking price is $13,000.00 O.B.O
Cosworth VQ35DE Includes:
Includes the following:
• Cosworth Forged H-beam Connecting Rods
• Cosworth Forged Pistons and rings
• Cosworth Tri-metal bearings
• Balanced to within .5 gram
• Complete blue-print assembly
• Ring gap set
• Bearing clearance set
• Deck height set
• Connecting Rod side clearance set
• Crankshaft end float set
Heads include the following:
• Ported and polished by Port Flow
• Multi angle valve job by Port Flow
• +1 MM Supertech Oversized Valves (Inconnel Exhaust Valves and
Stainless Steel Intake Valves).
• Supertech Titanium retainers
• Supertech Dual Valve Springs
• Cosworth ZK2 270 degree cams
Other things included with the Long Block package:
• ARP L19 Head Studs
• Cosworth Head Gaskets
• NISMO Thermostat
• RevUP Oil Pump
This motor is complete and ready for your high horsepower build. As stated above, I would like to sell the motor as all one piece…asking price is $13,000.00 O.B.O.
The Motor is at Corner 3 garage in lake forest!!
Only About 7000 miles on the motor.
Tuned at 550HP with 13.5PSI boost on the APS extreme kit.
Asking $10k for the motor package.
INCLUDES THE CARBONETIC CLUTCH!!!
Present state:
When it was first built!
Extras will be included for an extra cost!
Cosworth intake manifold
Technosquare Tadashi tuned ECU!
-Mike
• Ring gap set
• Deck height set
• NISMO Thermostat
• RevUP Oil Pump
Present state:
-Mike
Guys...this is my motor. Im silver g on G35Driver.
I asked Mike @ Corner 3 Garage to help me out with the sale because I am super busy at work. I will work on the price for anybody that wants it.
Just so everyone knows this motor is in perfect condition. It is a Cosworth Short block 8.8:1 compression (balanced and blueprinted by cosworth). Heads are done by Port Flow with complete port and polish, with +1MM oversized valves (Supertech inconnel exhaust valves and stainless steel intake valves), Supertech Titianium retainers, Supertech Dual valve springs, and it comes with Cosworth ZK2 cams (270 degrees).
The engine is a complete long block ready to install. It will come with ARP L19 head studs, rev up oil pump, NISMO thermostat, timing chains, polished cam and timimg covers etc...I will even throw in the Carbonetic Triple Plate clutch. This whole motor has less than 7,000 miles and has been maintained very well. Like I said I will work on price...motor has to go!!!
Mike I have dropped the price of the long block to $10,000.00, and I have thrown in the Carbonetic Triple plate clutch in with that price. Go ahead and update the thread.
Everyone this needs to move!!
Thanks Dan! He is right guys! I was only runing 13 psi making 550whp without breaking a sweat on the APS Extreme TT kit. This motor makes power effortlessly.
