Lookee what just arrived! *Clue - "L"*
Old Dec 9, 2004 | 06:12 PM
metalz's Avatar
metalz
it really finishes off the look of the car really well...pricy but if I had the money well worth it
Old Dec 10, 2004 | 04:24 AM
Daewoo's Avatar
Daewoo
Dave -- u bastard
Great buy. Can't wait to see her in the spring! Time for some air don't u think?
U gonna turbo/SC her this spring or what? I am and will be doing the install myself (then getting someone to tune it). I will likely do a SC. Maybe we can hook up and do urs first or mines etc. let me know man if u r thinking about it. I have a three car garage and air tools.
Let us know how she feels when everything is installed.
Old Dec 13, 2004 | 09:26 PM
D@ActiveTuning's Avatar
D@ActiveTuning
Daewoo - I'm hoping to have the APS TT in around April or so, but I will not be doing the install. I'd love to help out with yours though..I've got a good friend that may be interested in helping out if you've got a warm garage that can offer a lot of insight and help.
Let me know if this pic works for you guys:
Old Dec 14, 2004 | 02:15 AM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
Pics don't work.
Old Dec 14, 2004 | 12:56 PM
Daewoo's Avatar
Daewoo
APS TT ... man I can't hang with you. But I will take u up on the offer for help. I will keep intouch. I should have everything by March or so.
When is ur kit coming and who is installing it. Local??
Old Dec 14, 2004 | 01:02 PM
D@ActiveTuning
I'll be having MRC Motorsports in NJ do the install and tune. Keep me updated on yours, that'll be a fun weekend or two
Here's the pics of the seats in my car. The fitment was actually good, except the drivers side hits the door. I think I know a way to resolve the issue and should have it fixed by next week.
Attached Thumbnails Lookee what just arrived! *Clue - "L"*-231203470vkjjqr_ph.jpg
Old Dec 14, 2004 | 01:08 PM
D@ActiveTuning
Numero dos
Attached Thumbnails Lookee what just arrived! *Clue - "L"*-231204148aiuolk_ph_edited.jpg
Old Dec 14, 2004 | 02:52 PM
Elitemotion's Avatar
Elitemotion
actually the seats are very comfy ... they use that aerospace foam stuff
Old Dec 15, 2004 | 08:21 AM
syf0n's Avatar
syf0n
Update me, I have had the same issue for nearly a year now! I have to use a little piece of scoth tape to prevent the leather from rubbing away under lateral acceleration...
Old Dec 16, 2004 | 10:56 AM
D@ActiveTuning
Alright I've got it installed as best as I could. This is what I did:
The front tabs on the brackets where the bolts go in were bent 10 degrees. The door side of the passenger side bracket has two washers under each bolt....the door side of the drivers door has three. The passenger side fits perfect, no rubbing whatsoever. On the drivers side, I had to drill the hole on the back left side (there is a prong that didn't fit in the pre-drilled hole all the way) a bit bigger. The drivers side fits with no rubbing, but if I turn hard, it hits the door...not too big of a deal. I may try one more washer and see if that looks ok and works.
Old Dec 16, 2004 | 12:06 PM
syf0n's Avatar
syf0n
That's what I did...since I have the orange seats, the fact that the door hits is more noticeable because it slowly wears away at the leather!
Instead of bending my brackets I actually used a cutting tool to widen the holes so the brackets shift back and forth. Even moved the whole way over, mine still hit.
Sube Sports should fire the sorry b@stard who makes those brackets...
Old Dec 16, 2004 | 12:11 PM
D@ActiveTuning
Yeah seriously, you would think if they make a bolt on bracket made specifically for our cars, they would make it at least fit the damn car lol.
Did you put tape or something to slow the wear on the leather where it hits the door?
Old Dec 16, 2004 | 12:29 PM
Red6's Avatar
Red6
Those were my old seats that are now in your car.
The only way they didnt hit the door was by using lots of washers stacked up evenly on both sides.
This is to tilt to tilt the seat a little bit.
I used about 12 washers per side (Driver and passager).
Your going to dent you door and damage the sides of the seats.
Elitemotion was the first to find that the washers solved the problem and it work for me too.
Old Dec 16, 2004 | 02:33 PM
ssc's Avatar
ssc
great looking seats, but damn, its expensive
Old Dec 16, 2004 | 02:34 PM
syf0n's Avatar
syf0n
Yes, I use two piece of scotch tape layered on top of each other. It prevents wear on the seat but does not do much for the dent in the door.
Next summer, when I am near a welding rig long enough, i am going to do a 100% custom hackjob on the brakcets....get them to fit the right way! Bend the seatbelt connector mounts in 10 degress and everything ese that needs to be corrected on these terribly crappy brackets.
azmo
Aug 12, 2002 12:28 AM
fairladyZ in Japan
Aug 4, 2002 09:03 PM
mbeguy
Jul 12, 2002 06:32 PM
infinite z
Jun 26, 2002 02:33 AM
Scafremon
May 29, 2002 03:03 PM
