what is the easiest way to upgrade my headlight for base model to real HID set??
Hi, everyone:
I thought OEM HID headlight kit can directly plug into my base model Z, until I removed everything and then found out....... PLUGS ARE DIFFERENT.
I need you guys' help here.
First, can I still use this kid and find a way to put the HID on my car?? For example, rewireing the kid or what??
Second, Just give up the OEM set and buy after market parts?? If this is the choice, which brand and model will you recommend??
Please help me out. I spent $600 for the OEM headlight Kit, seriously dont want to waste any more money to try something doesnt work. Sincerely appreciate your guys' help. .
Hi, yobri:
Thanks for your response. You made me feel live again. But this morning I just came back from the Nissan dealership, actually, they removed everything for me(sorry to lie to you all), and also they showd me the difference between two plugs. They said if I insist on putting these kit on, they need to replace all the wire on my car, and it will take another 10 hours to finish it. By the way, they still charged me $160 for nothing. No, $160 to let me know two plugs are different.
So, if you are really sure that it can be done, please give me a direction to reach that PDF file. This time, I will do it by myself. Lousy dealership..........
Thank you so so so so much.
Go to Control Panel > Private Messages > (scroll down) New Message
Type in: Jun
in the Recipient text box.
Fill in the Subject and Your Message text boxes and then press the Send Message button.
Type in: Jun
Thanks a lot. yobri.
I sent the message to Jun already. I cant wait to see my Z with white HID headlight. But about the dealership............. again, I dont know what else I can say to them.
Last time they did the alignment for me, then my steering wheel was still crooked. This time charged me $160 for nothing. It it my fault. I am not supposed to go there anymore. Damn.
I did the oem route. This is all that you need:
The only thing you have to do is cut your h7 connectors off and solder the plugs that comes with the ballasts, after that everything is straight foward. I spent around $250 for the oem upgrade and did the job in about 30 minutes and another 15 to get the alignment just right. Let me know if you have any questions.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Tochigi_236
Sep 27, 2015 03:40 PM
